H22 Type S swap into 98 DX
Old Feb 26, 2007 | 02:35 PM
futrhondaownr's Avatar
Default H22 Type S swap into 98 DX
im planning on purchasing a complete h22 type s swap from Hmotorsonline(http://www.hmotorsonline.com/s...30019) and want to know what else do i need to swap it into a 98 Civic DX.
Can i use the axles and mounts that come with the motor? what do i need to keep a/c?
Old Feb 26, 2007 | 03:11 PM
3ghandles's Avatar
Default Re: H22 Type S swap into 98 DX (futrhondaownr)
about the mounts....definetely not.
u need to checkout hasport. they gout the h series into ek mounts..
the axles not sure.
the ac....idk
Old Feb 28, 2007 | 08:54 AM
98vtec's Avatar
moderator emeritus
Default Re: H22 Type S swap into 98 DX (3ghandles)
u dont want to use a type S. Type S has an atts unit which you will not have any use for. You want the EuroR or SiR spec. They are like the base model h22's but the trannys come with LSD.
Old Mar 7, 2007 | 03:51 PM
atts unit??? is that the only reason not to go type s? is there a way around that?
Old Mar 7, 2007 | 08:16 PM
powerflow's Avatar
Default Re: (futrhondaownr)
Pretty much, euroR and SIR S spec is the way around the type S. The ATTS unit and the trans cant be used with a swap. Even if you used the type S long block, the mid-shaft would have to be modified to mount on the block.
Old Mar 8, 2007 | 12:20 PM
thanks this is gonna save me alot of money
Modified by futrhondaownr at 8:25 PM 3/8/2007
toukao35
Jul 10, 2017 08:28 PM
soclean1k_JDM
May 20, 2009 12:57 AM
WeekH22#2
Nov 8, 2005 07:13 PM
