IPOD w/ stock radio [em1]
Old Feb 26, 2007 | 02:11 PM
Rosetta Stoned's Avatar
Default IPOD w/ stock radio [em1]
Yo guys i was wondering if any of you have hooked up an ipod to your stock 99-00 civic SI radio. Im in desperate need of a radio and a friend says he has an SI radio he would sell cheap.
Now ive seen the FM tuners that i know will work for sure, but im thinking its not going to sound very good. And ive also seen these cables that connect the ipod through an aux port, but im not sure if this radio has an aux port on it.
So have any of you guys dealt with this? What was your solution?
Thanks.
Old Feb 26, 2007 | 02:20 PM
JDM JETSMAN's Avatar
Default Re: IPOD w/ stock radio [em1] (Rosetta Stoned)
The FM transmitters get a little fuzzy sometimes. For the best sound get a deck that has an ipod hookup and just control the ipod through your deck.
Old Feb 26, 2007 | 02:47 PM
B18C_EJ8's Avatar
^^ Thanks for NOT answering the question...
To the OP, get one of these:
http://www.logjamelectronics.com/ipodacura.html
Old Feb 26, 2007 | 02:58 PM
fcm's Avatar
fcm
Old Fart
If the HU you are looking at has a CD changer port, as I believe all Honda/Acura HUs from about 94 had then yes you can get an adapter for that port, from cheap units that have the Honda plug on one end and a set of femal RCAS on the other, [AUX adapter] to the more expensive, but better, Ipod specific adapter, Honda plug on one end and Ipod docking port plug on the other end. 94
http://www.pac-audio.com/produ...Input
http://www.pac-audio.com/produ...ation
http://www.pie.net/store/index...y=133
http://www.pie.net/store/index...y=181
http://www.soundgate.com/
http://www.blitzsafe.com/blitz....html
here is another 600,000+ sites... http://www.google.com/search?s...adios
Old Feb 26, 2007 | 03:36 PM
Default Re: IPOD w/ stock radio [em1] (fcm)
you guys rock so very hard.
Old Feb 26, 2007 | 03:45 PM
B18C_EJ8's Avatar
We know.
Old Feb 26, 2007 | 03:55 PM
fcm's Avatar
fcm
Old Fart
94
Old Feb 27, 2007 | 05:08 PM
These are the pics of the radio in question. I dont see any other ports besides the harness plug and antenna port.
:edit: you guys still rock.
Old Feb 27, 2007 | 05:16 PM
B18C_EJ8's Avatar
The smaller 14-pin plug to the left of the main power/speaker connector is the changer port...
Old Feb 27, 2007 | 05:18 PM
B18C_EJ8's Avatar
Edited... Get this one:
http://www.logjamelectronics.c....html
Quoted from above link:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote"># For Honda: Compatible with 1998 Accord plus all Honda models from 1999-2005 except all Passport and 2003-2006 Honda Accord, 2003-2006 Honda Element, 2005-2006 Honda Odyssey, 2005-2006 Honda CR-V, 2004-2006 Honda S2000.(
# Plugs into the rear of the factory radio.
# Factory radio must have an unused 14-pin square connector socket at the rear of the radio.</TD></TR></TABLE>
Old Feb 27, 2007 | 05:30 PM
Default Re: (B18C_EJ8)
I wish i could paypal you a hug.
LOL
Old Feb 27, 2007 | 05:44 PM
B18C_EJ8's Avatar
However, did some more reading and you can get by with this cheaper with a plain old Aux-Input adapter, since the one in the link 2 posts up won't control the iPod through the deck anyway (you still need to press buttons on the iPod)...
This one will work just as well, and it's almost half the price. http://www.logjamelectronics.com/piehon98aux.html
Old Feb 28, 2007 | 05:43 AM
fcm's Avatar
fcm
Old Fart
I would go with the first one, the cheaper one leaves you with a set of RCA inputs you will also need a RCA to docking port connector, [not so cheap] the RCA to mini phono jack is much cheaper but you lose SQ. 94
Old Feb 28, 2007 | 05:47 AM
B18C_EJ8's Avatar
^^ True that...
Old Nov 12, 2007 | 09:03 AM
CeoStatus0's Avatar
i'm looking to getting one of these... i'm just wondering if anyone can tell me the difference in SQ when using an AUX and a ipod interface.
I have a AUX jack that came standard in my other ride.. but the SQ is sooo bad that I don't even bother with using the ipod/mp3 in that car
Old Nov 12, 2007 | 09:41 AM
gabebauman's Avatar
Default Re: (CeoStatus0)
I'm thinking of getting one of these: http://www.autotoys.com/x/prod...=5517
I have a 98 Civic Ex with the factory head unit.
Old Nov 12, 2007 | 12:13 PM
fcm's Avatar
fcm
Old Fart
Default Re: (gabebauman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gabebauman &raquo;</TD></TR><TR><TD CLASS="quote">I'm thinking of getting one of these: http://www.autotoys.com/x/prod...=5517
I have a 98 Civic Ex with the factory head unit.</TD></TR></TABLE> Pretty sure your 98 Civic still had the 8pin din plug not the new 14 pin plug, in which case the adapter you link will not work.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CeoStatus0 &raquo;</TD></TR><TR><TD CLASS="quote">i'm looking to getting one of these... i'm just wondering if anyone can tell me the difference in SQ when using an AUX and a ipod interface.
I have a AUX jack that came standard in my other ride.. but the SQ is sooo bad that I don't even bother with using the ipod/mp3 in that car</TD></TR></TABLE> It's not a question of AUX or iPod adaptor, you can get an AUX input iPod adapter that uses the iPods head phone jack, the result is poor SQ, [your amplifying an amplified signal] what you want is an iPod adapter the uses the iPods docking port to an AUX input, [pre amp output to pre amp input] much better SQ. 94
Old Nov 12, 2007 | 12:34 PM
gabebauman's Avatar
Default Re: (fcm)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fcm &raquo;</TD></TR><TR><TD CLASS="quote"> Pretty sure your 98 Civic still had the 8pin din plug not the new 14 pin plug, in which case the adapter you link will not work.
Ah...yeah...I goofed...this is the link I meant to post: http://www.autotoys.com/x/prod...10152
Example of my oem head unit.
And the eight pin would be the white circle socket on the far right.
However...this one would allow me to control the iPod thru the head unit.
http://cgi.ebay.com/ebaymotors...8.lVI
Old Nov 12, 2007 | 10:36 PM
CeoStatus0's Avatar
Default Re: (fcm)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fcm &raquo;</TD></TR><TR><TD CLASS="quote"> It's not a question of AUX or iPod adaptor, you can get an AUX input iPod adapter that uses the iPods head phone jack, the result is poor SQ, [your amplifying an amplified signal] what you want is an iPod adapter the uses the iPods docking port to an AUX input, [pre amp output to pre amp input] much better SQ. 94</TD></TR></TABLE>
SQ on this sucks? http://gromaudio.com/aux.html
so this wouold be better SQ and these two are at the same level?
http://gromaudio.com/ipod.html
Old Nov 13, 2007 | 06:17 AM
fcm's Avatar
fcm
Old Fart
94<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CeoStatus0 &raquo;</TD></TR><TR><TD CLASS="quote">
http://www.logjamelectronics.c....html</TD></TR></TABLE> As I said, docking port instead of head phone jack. 94
Old Nov 17, 2007 | 08:49 PM
clean3two3's Avatar
wont u need the code from the dealer to install that on another car
hondarookie991
Audio / Security / Video
May 23, 2009 08:09 AM
redsled00
16
Jan 12, 2008 12:33 PM
importboi22
Oct 27, 2005 05:42 PM
JforJonathan
Apr 17, 2003 07:21 AM
ekb18c
Jun 3, 2002 08:57 AM
