USDM axels on a JDM motor???
Old Feb 26, 2007 | 01:48 PM
hatchy69's Avatar
Default USDM axels on a JDM motor???
will USDM axles work on a JDM motor??
Old Feb 26, 2007 | 01:49 PM
MR.johnson's Avatar
Default Re: USDM axels on a JDM motor??? (hatchy69)
yes.
Old Feb 26, 2007 | 01:58 PM
killektiv's Avatar
Default Re: USDM axels on a JDM motor??? (MR.johnson)
I was always under the impression that they would not since alot of the JDM trannys have 1/2 shafts. I recently did a b16 swap on a 93 hatch and the USDM axles will not fit. I had to order new ones and just use the 1/2 shaft that came with the JDM motor and tranny.
My old motor had one long axle on the drivers side.
Old Feb 26, 2007 | 02:08 PM
MR.johnson's Avatar
Default Re: USDM axels on a JDM motor??? (killektiv)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by killektiv &raquo;</TD></TR><TR><TD CLASS="quote">I was always under the impression that they would not since alot of the JDM trannys have 1/2 shafts. I recently did a b16 swap on a 93 hatch and the USDM axles will not fit. I had to order new ones and just use the 1/2 shaft that came with the JDM motor and tranny.
My old motor had one long axle on the drivers side.</TD></TR></TABLE>
all Bseries have half shafts.
Old Feb 26, 2007 | 02:33 PM
killektiv's Avatar
/\ Well there you go. I stand corrected.
Old Feb 26, 2007 | 02:34 PM
MR.johnson's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by killektiv &raquo;</TD></TR><TR><TD CLASS="quote">/\ Well there you go. I stand corrected.</TD></TR></TABLE>
your thinking of D-series axles.
Old Feb 26, 2007 | 02:36 PM
dem0nk1d's Avatar
i think he is saying that inside of have a "Intermediate Shaft on the driverside" and the a half shaft. it was one long axel
Old Feb 28, 2007 | 04:59 PM
killektiv's Avatar
Default Re: (dem0nk1d)
yah I was thinking of D-series axels.
Boosted_01 R
Jun 21, 2009 04:31 PM
wing.jai
May 18, 2009 11:34 AM
asmallsol
Nov 22, 2005 08:53 AM
1.8LHatch
Jul 31, 2004 08:16 PM
stealthhatch
Apr 30, 2004 10:44 PM
