Help code 43 plus other issues...
Old Feb 26, 2007 | 01:32 PM
Samuels's Avatar
Default Help code 43 plus other issues...
Ok i installed my new fuel rail a couple weeks back and i noticed that the o-ring on the top of 1 of the injectors was letting out air or whatever it was my tuner he could see it so it was replaced..
For some reason every since i keep getting a code 43 thats obviously some fuel code.. My tuner/builder told me don't worry about it to reset everything by unplugging the ECU and/or battery i did both.. It still will come back then i'll cut off the car cut it back on and its gone.. At this same time this stuff was done the o2 was taken off and put back on after my manifold was ceramic coated someone said it could be a 02 issue..
It also acts like it has a vacuum leak on my boost guage after warming up it'll idle from like 1k down to around .6 after driving around alittle and sometimes has cut off.. Up until then this thing ran perfect no problems at all..
I'm also trying to figure out where is the best place to run a vacuum source from to my fast-turbo vacuum manifold?? I have alot of nipples on my AEBS IM but did'nt no if it could run everything and still have good vacuum.. I need a good vacuum because i'm gonna be hooking up my AVCR I will have the 2 ports including the pressure signal for the AVCR in the vacuum manifold.. Along with the side WG port,BOV..
Any help,ideas??
Old Mar 4, 2007 | 05:12 PM
Samuels's Avatar
Default Re: Help code 43 plus other issues... (Samuels)
update no vacuum leak..
any ideas??
i changed that o-ring on the top of the injector is it possible i messed up the tune at idle??
What else could it be??
Old Mar 7, 2007 | 01:22 AM
orb's Avatar
orb
I'm seeing the same code on my car. I found this post by searching for an answer to my problem. If anyone has any advice, that would be sweet!!
Old Mar 10, 2007 | 06:40 PM
Samuels's Avatar
Default Re: (orb)
i know its a fuel related code but its driving me crazy.. I got this code after taking off my o2 then reinstalling it after getting it coated.. I've been told it could be my o2 being old dunno..
Old Mar 11, 2007 | 07:58 PM
RA61825's Avatar
im running the same problem, with the iddle and code 43 . Did you figure out what it was? let me know
Old Mar 12, 2007 | 04:05 PM
Samuels's Avatar
Default Re: Help code 43 plus other issues... (RACERX72)
not sure bro i retuned it and no check engines so far in 2 days at the track....
Old Mar 13, 2007 | 04:32 PM
poorman's type-r's Avatar
* B A N N E D *
damn... my hatch is doing the same thing too dont know what going on
Old Mar 14, 2007 | 02:38 PM
Samuels's Avatar
Default Re: Help code 43 plus other issues... (poorman's type-r)
don't sound like anybody knows whats wrong around here...
Old Mar 14, 2007 | 10:50 PM
orb's Avatar
orb
Well, this sucks. I've had this code for a couple of months now and NO ONE seems to know anything about it, including tuners/mechanice I've spoken to. Now I'm seeing the drop in idle as well. Didn't have that before. I've already replaced my 02 sensor and had no luck. I picked up another one and will be trying that again just to see what that will do. My stock fuel pump has been replaced with a Walbro, but still I see that damn code. Blah.
Old Mar 14, 2007 | 11:00 PM
full Circling's Avatar
From: That's the wrong tone... I'm Skunk2 certified.
i was getting a code 43 from a clogged cat. it went away as soon as i installed a test pipe and reset my ecu. it could be many other things, but don't overlook the cat converter.
Old Mar 15, 2007 | 10:26 AM
romJones's Avatar
Default Re: (full Circling)
much like "orb"...
i replaced my o2 sensor
and the code WENT AWAY ... for a good 3 months
but has since RETURNED
i too would like to know the root of this problem
Old Mar 15, 2007 | 01:20 PM
^^see above post
Old Mar 15, 2007 | 02:34 PM
orb's Avatar
orb
Thanks, but in my case that's not it. I just put a new cat on.
I hate to thread-jack, but I'm just trying to keep this alive and get stuff fixed here.
Old Mar 15, 2007 | 02:48 PM
Samuels's Avatar
Default Re: (orb)
I have no cats all 3" straightpipe turbo car..
Old Mar 15, 2007 | 04:37 PM
SleepinEh's Avatar
code 43 is fuel system code.. this is anything from injectors to pump to relay to wiring.. any of it could cause the problem.. even the regulator for that matter.. its trial and error as far as i can tell from there.. i just picked up a teg with good ole 43.. it will sputter a bit in higher rpm
Old Mar 20, 2007 | 02:06 PM
* B A N N E D *
fix mine... it was the O2 sensor
Old Mar 20, 2007 | 09:40 PM
orb's Avatar
orb
Default Re: (SleepinEh)
No, there is no sputtering on my car.
Old Mar 21, 2007 | 04:59 PM
orb's Avatar
orb
I tried cleaning my injectors by hand, but the code came back after 4 or 5 warm up cycles. Seems to have helped the idle issue though. Anyone else tried anything lately?
Old Mar 31, 2007 | 12:31 AM
orb's Avatar
orb
No one has had this issue? Really, I have looked everywhere it seems. I have asked a multitude of people, but to no avail. I have posted on a number of Honda-related sites, but I just get nothing back. Does anyone have any resources available to them that they might use to look into the issue for us? Say, for example, you work at a shop and can look at a manual or troubleshooting chart or something similiar? I recently went to the dealership and bought a new banjo nut/washer thinking that the small leak I noticed there may have caused the code, but... NOPE.
Old Apr 16, 2007 | 02:03 AM
orb's Avatar
orb
Default Re: (orb)
Still seeing this. Anyone have any luck yet?
Old Apr 16, 2007 | 09:37 AM
RA61825's Avatar
Default Re: (orb)
damn i havent had any luck either
Old Apr 16, 2007 | 01:57 PM
civical4dr's Avatar
code 43 is usually caused by a weak fuel pump faulty regulator or a faulty o2 sensor
Old Apr 16, 2007 | 02:00 PM
civical4dr's Avatar
i can fix these problems at my garage in livingston louisiana let me know if yall are interested
Old Apr 22, 2007 | 03:37 PM
orb's Avatar
orb
Default Re: Help code 43 plus other issues... (civical4dr)
Thanks man, I'll look into this.
Old Apr 26, 2007 | 03:23 PM
orb's Avatar
orb
Default Re: Help code 43 plus other issues... (orb)
Nope, not the fuel pressure regulator. Replaced that with a known good one off a running engine with no codes and I still see that #43. This sucks. I plan to boost in a few months. I need to get this **** cleared up.
