brake upgrade with stock rims
Old Feb 26, 2007 | 01:23 PM
ali7up's Avatar
Default brake upgrade with stock rims
i was going to upgrade with the following:
rear disc, brembo v6 rotors all around with pbr pads, legend 2 pitons calipers in front my question will this fit in my stock 14 inch rim or not? thanks
and when looking for pads or brake lines do i get accord or lengend pads?
Modified by ali7up at 2:56 PM 2/26/2007
Old Feb 26, 2007 | 02:24 PM
ali7up's Avatar
Default Re: brake upgrade with stock rims (ali7up)
also does anybody know much at the package at tas storee they are selling 4 oem rotors and pads for $145 at
http://www.secureleadercom.com...age=1
thanks
Old Feb 27, 2007 | 05:09 AM
TouringAccord's Avatar
H-T Order of Merit
no, the AV6 or Legend Dual-Piston brake upgrade will not fit under 14" rims, you need atleast 15".
For brake pads, see the thread below (It's also located in the FAQ)
https://honda-tech.com/zerothread/1882824
That set of rotor and pads are not OEM. The rotors are just their stock replacement rotors (don't even give a manufacturer or brand name) and the pads are their TAS Line of semi-metallic pads (probably rebadged but don't know the manufacturer). Personally I would stick to Brembo rotors all around and match a set of pads to it that suites the driving conditions the car is most going to be seeing.
Red4drLSintegra
Apr 22, 2008 08:14 PM
mrinno
Jul 23, 2007 05:56 PM
Rhood
Jan 23, 2007 05:48 PM
E dwinbon G
16
Dec 11, 2004 12:25 PM
ophdehEEzY
Mar 8, 2003 07:06 PM
