ZEX 105300 cam VTEC higher or lower?
Old Feb 26, 2007 | 11:24 AM
fdjizm's Avatar
Default ZEX 105300 cam VTEC higher or lower?
since this cam has a higher profile than stock, would i benefit from raising the vtec to keep it in the low profile longer and make more power, or lower the vtec so i can jump into the high cam profile sooner?..
Old Feb 26, 2007 | 04:26 PM
fdjizm's Avatar
wow and im in a tech forum..
Old Feb 26, 2007 | 05:18 PM
doood's Avatar
been there done that
Default Re: (fdjizm)
put it on a dyno and see where the ideal x-over point is
Old Feb 27, 2007 | 03:29 AM
fdjizm's Avatar
no dyno's nearby.. so nobody knows about when you put in a new cam, should your new low profile last longer?..
Old Feb 27, 2007 | 06:33 AM
Padawan's Avatar
Darth ModerVader
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fdjizm &raquo;</TD></TR><TR><TD CLASS="quote">no dyno's nearby..</TD></TR></TABLE>
Then leave the VTEC point where it is. When you decide to properly dyno-tune the setup, you'll discover better driveability and greater power output. An aggressive cam is not a "drop-in" item.
Old Feb 27, 2007 | 07:00 AM
Libertariat's Avatar
Ek Forever y0!
Default Re: (Padawan)
I agree, a cam isn't something you can just throw on, ask someone the magic setting, and BAM, instant Gains.
That only works in the land of Unicorns and Rainbows.
D-Rob
Engine Management and Tuning
Apr 14, 2008 11:39 PM
Johnny_9
May 13, 2006 05:35 PM
legoman
Jan 15, 2005 08:01 PM
sbradye
May 20, 2004 07:31 AM
