rear camber..
Old May 21, 2002 | 10:25 AM
p0pe's Avatar
Default rear camber..
Around 2-3 months ago there was a topic about a "cheap fix" for rear camber,
anyone remember what I'm talking about? If so can you explain this?
Old May 21, 2002 | 10:26 AM
John's Avatar
New User
Default Re: rear camber.. (p0pe)
01GSR had some good photos if I remember correctly. He used 2mm washers in the rear to push out the camber.
Old May 21, 2002 | 10:27 AM
CmptchAV6's Avatar
it is the washer trick. It is really easy to do but I dont know how to describe where you put the washers. Maybe someone still has the pics that will show how to do it
Old May 21, 2002 | 05:41 PM
p0pe's Avatar
Default Re: rear camber.. (CmptchAV6)
ttt
Old May 21, 2002 | 07:35 PM
John's Avatar
New User
try IMing 01GSR or experimenting with the search.
Old May 21, 2002 | 07:43 PM
scrubachu's Avatar
Default Re: rear camber.. (DunReit)
real easy. there are 2 bolts, 14mm i think, that bolt the rear arm into the frame. just undo the bolts and put some washers in there and bolt em back. the washers push out the rear control arm and make the tire sit more even on a lowered car. depending on how low your car is, you may need to get longer bolts, which you can find at a hardware store. if your drop is only1 or 2 inches, then you should be able to use the bolts you have. hope this helps. also, i would recommend you have an alinment place do it because they will make sure that the camber is 100% right. i have this done on my accord, and i have no uneven wear on any of my tires
Old May 21, 2002 | 07:50 PM
4doorH22's Avatar
Default Re: rear camber.. (scrubachu)
They say more than two washers and you need longer bolts. If it were me I'd get longer bolts if I needed more than one washer...
Old May 21, 2002 | 08:42 PM
H23 Power's Avatar
Default Re: rear camber.. (4doorH22)
Old May 21, 2002 | 08:43 PM
p0pe's Avatar
Default Re: rear camber.. (01GSR)
thanks man
4doorH22's Avatar
That's a Civic/Teg rear, right?
Old May 21, 2002 | 08:46 PM
H23 Power's Avatar
Old May 21, 2002 | 08:47 PM
H23 Power's Avatar
yes, same concept tho
Old May 21, 2002 | 08:48 PM
H23 Power's Avatar
one washer equals roughly 1 degree of camber
i got new bolts on my GSR even though i only used one washer
Old May 21, 2002 | 08:50 PM
p0pe's Avatar
any special washer size?
Old May 21, 2002 | 08:52 PM
H23 Power's Avatar
forget what i said...
just read this
http://www.jdmfan.com/technical/suspension/rear_camber/
Old May 21, 2002 | 08:54 PM
H23 Power's Avatar
but now that I think about it...I only had a 1.25" drop but 1 washer was PLENTY
they say 2 washers for a 1.5" drop, but I wouldn't do that...
2 washers on my friends with a 1.8" drop was just right...but if anything you want negative camber, not positive, so go with the lower number of washers
Old May 21, 2002 | 09:42 PM
CmptchAV6's Avatar
my friends integra only took 2 washers per bolt for a 2.5 inch drop. we tried 3 washers at first but then he had positive camber and it looked like **** so we went with 2 instead.
Old May 21, 2002 | 10:51 PM
H23 Power's Avatar
yeah, that sounds about right
1 washer per inch dropped is a good estimate
Old May 21, 2002 | 11:33 PM
vtec94's Avatar
New User
so... what's the size of the washer that we need to use for our 5th G accords?
and how much difference did it make per one washer?
thanks bunch! :D
Old May 21, 2002 | 11:35 PM
poison's Avatar
ahh, never mind, ya got it ;P
[Modified by poison, 1:35 AM 5/22/2002]
Old May 22, 2002 | 06:30 AM
Stew Pidasso's Avatar
Definitely <U>DO NOT</U> buy a friggin camber kit for the rear.I bought one which replaces the upper control arm with a large threaded bolt and a ring at the end to fasten to the ball joint. Anyway mine on the driver's side broke and on the passenger side was very bent and about to break. I bought it before I was on H-T and paid about 120 bucks a corner. The worst part is when I had them put on the mechanic threw the old upper control arms away. I now have to pay 76 bucks apiece for new ones or go to a junkyard.
ALWAYS keep your old parts!!!
nk2k2
17
Sep 4, 2009 01:23 AM
lil k
May 19, 2003 12:22 AM
dellman177
Oct 3, 2002 06:59 PM
fcuked
10
May 8, 2002 09:18 PM
albert butterbikini
Jan 27, 2002 02:00 PM
