rear disc concersion gone bad....
Old Feb 26, 2007 | 10:16 AM
ExclusiveCRX's Avatar
Default rear disc concersion gone bad....
wen i got my 1st ls swap i purchased the whole 90 integra for 300$ so i took advantage of it and put da motor in my rex and the front and rear disc setup, y is it that my rear tires taper into the car they basically go in like so....... / ive driven like this for 3 monthes now and it stops and all, there doesnt seem to be much wear in the tires but im jus conserned that it might become n issue aside from cosmetic.....
Old Feb 26, 2007 | 10:30 AM
89efDUSTY's Avatar
Default Re: rear disc concersion gone bad.... (ExclusiveCRX)
did you use the CRX or Integra LCAs ????
Old Feb 26, 2007 | 11:39 AM
FIGARILA's Avatar
Default Re: rear disc concersion gone bad.... (89efDUSTY)
it's been like this for 3 months? dude swap back the original rear LCA's ASAp
Old Feb 26, 2007 | 11:46 AM
dephtone's Avatar
Yeah for some reason it did that one my friends Sedan when he put the full integra suspension on his car. He thought he had a bent frame, took it to get alined, they were like I have no idea but i can't aline the rear wheels. So swap them back like Figarila said.
Old Feb 26, 2007 | 11:49 AM
dr_latino999's Avatar
Default Re: (dephtone)
You used the Integra LCA and you probably used the Compensator arm as well, capital no noes.
Old Feb 26, 2007 | 11:50 AM
FIGARILA's Avatar
you should take a pic for future reference.
Old Feb 26, 2007 | 12:57 PM
89efDUSTY's Avatar
Default Re: (FIGARILA)
bwahahaha everyone is saying to swap it back...he hasn't even answered my post , but we all know thats probably his problem
Old Feb 27, 2007 | 06:15 AM
Default Re: (89efDUSTY)
appreciate the help didnt get back sooner kuz of skool but i guess i gotta get a hold of ome si discs kuz i got rid of my originals so for the time being im gonna have ot ride it out.
Old Feb 27, 2007 | 11:24 AM
#1nismo's Avatar
Default Re: (ExclusiveCRX)
its got nothing to do with the brakes you dumbass its the lower control arm they are longer then the stock crx LCA theyfore creating negative camber
Old Feb 27, 2007 | 04:24 PM
Default Re: (#1nismo)
really do wen i switch dem n it dont work i can over there n drop kick u in ur face right? kuz idk who u thought u were talkin to like dat. u dnt kno me dog so dnt come out ur face n be a computer thug! next time u post n wanna be disrespectful rememba u behind a screen, and dat dnt make u tough!
Old Feb 27, 2007 | 05:15 PM
gator88's Avatar
gangsta talk^^ me not cool n nuff to learn how to type so cool?
just playing man, but i could never learn to type like that
Old Feb 27, 2007 | 08:43 PM
Default Re: (gator88)
lol it comes natural with the attitude and the laziness to actually sit there and type out all the words correctly
Old Feb 27, 2007 | 08:48 PM
ChickenH's Avatar
cant he stack about 5 10mm washers under each upper controll arm bolt mount against the body and put longer mounting bolts on ? or is it more drastic than that?
Old Feb 27, 2007 | 08:57 PM
Ls_dx's Avatar
Default Re: (ChickenH)
are we talking about toe or camber >??
Old Feb 27, 2007 | 09:12 PM
ILcrxsi1's Avatar
I tell doctors what to do
Default Re: (Ls_dx)
juz throe sum d's on dat bich an it'll role str8 fo sho
Old Feb 28, 2007 | 01:17 AM
~sp33~'s Avatar
EFB055
Wich wyre do eye cut 4 b0ost. lol.
Old Feb 28, 2007 | 06:47 AM
Targa250R's Avatar
be professional
It is almost certain that you swapped the Integra compensator arms and possibly other control arms onto your car, which is a huge no-no. You have to swap the original Civic/CRX compensator arms - and any other control arms you changed - back onto the car. The only arm that can be swapped from a DA for the rear disc conversion is the trailing arm - and even those aren't necessary, because you can bolt the disc hub assemblies up to your stock trailing arms (this is usually done when a donor trailing arm is bent).
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ChickenH &raquo;</TD></TR><TR><TD CLASS="quote">cant he stack about 5 10mm washers under each upper controll arm bolt mount against the body and put longer mounting bolts on ? or is it more drastic than that?</TD></TR></TABLE>
No. This is not the same problem you're thinking of. Alignment is not something that you can halfass, or it will end up quickly wasting a lot of your money and time.
Old Feb 28, 2007 | 10:21 AM
steveo135's Avatar
Default Re: (ILcrxsi1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ILcrxsi1 &raquo;</TD></TR><TR><TD CLASS="quote">juz throe sum d's on dat bich an it'll role str8 fo sho </TD></TR></TABLE>
LMFAO! fo sho!
Mr.Cheezil
Apr 10, 2011 10:52 PM
olddohc
Feb 1, 2011 01:51 PM
88 EF Hatch
Mar 3, 2009 08:47 AM
93egboosted
Jan 5, 2008 09:51 AM
fast hatch
Suspension & Brakes
Nov 23, 2005 07:18 AM
