stock headlight Q
Old Feb 26, 2007 | 09:25 AM
choppedndropped's Avatar
Default stock headlight Q
I've been working on a civic that was wrecked in the front pretty badly. I had to bend the new radiator support some in order to weld it on in the right spots. after installing the headlights i notice they aren't level, i worked with them for like 2 hours and i can't get them straight. there is an adjustment on the back, i turned it and turned it doesnt seem to make a difference. The lights are pointing straight ahead, but ones too high and the other is too low. can i adjust the hieght without moving the light housing? and what do the adjustments on the back do? I saw there is an inner-housing, how do i adjust that?
Old Feb 26, 2007 | 09:28 AM
da_dude's Avatar
Add some washer on the lower headlight until it is near or level with the other headlight.
Old Feb 26, 2007 | 09:31 AM
Default Re: (turb20_vtec)
so in other words there is no adj. I figured that since there is a level inside the housing. this is such a pain in the *** cuz everying is bent.
Old Feb 26, 2007 | 10:12 AM
platinumx6's Avatar
Default Re: (choppedndropped)
mine is like that with low beams, but perfect with high beams. Guess how i drive around?
Old Feb 26, 2007 | 11:07 AM
da_dude's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by choppedndropped &raquo;</TD></TR><TR><TD CLASS="quote">so in other words there is no adj. I figured that since there is a level inside the housing. this is such a pain in the *** cuz everying is bent.</TD></TR></TABLE>
Adjustable headlight? Not that I know off. That is to adjust your beam light, not your headlight.
Old Feb 26, 2007 | 11:19 AM
styol's Avatar
well, they are adjustable in a way... atleast for my del sol headlights there is a screw on each side of the headlight to adjust the tilt of the lightbulb to raise or lower the beam put out
when you say "The lights are pointing straight ahead, but ones too high and the other is too low." it sounds like you might be talking about the beam, which should be able to be easily adjusted with a philips head screw driver
theres a screw on each side of the headlight that you might've thought was for something else, but that might be your golden ticket give it a try -- cant hurt
SH67H
Honda Civic (2006 - 2015)
Aug 10, 2014 07:49 PM
Kisses_89_HB
Jan 29, 2004 07:16 PM
dLo GSR-stolen-now-WRX
May 3, 2003 12:02 AM
May 20, 2002 08:51 AM
fiebru1119
May 9, 2002 06:03 AM
