chipped ecu and ticking sound?
Old Feb 26, 2007 | 07:40 AM
loner714's Avatar
Default chipped ecu and ticking sound?
running a chipped ecu on a stock engine hurt the motor? when i take my car into the higher rpms i hear alot ticking noises from the engine. when i drive normal it sounds ok. would could it be?
Old Feb 26, 2007 | 08:10 AM
Dogginator's Avatar
Daisy... Daisy...
Default Re: chipped ecu and ticking sound? (loner714)
Are you exceeding the stock rev limit? Yes, a chipped ECU can hurt the engine. You should know what you are running.
Old Feb 26, 2007 | 08:12 AM
Rikter's Avatar
Also, what's the chip? Ebay special or a real chipped ecu? What's the tune for on the chip and what are you not running that the chip is setup for?
-Rik
but yes, driving a car with a tune that it isin't setup for via the chip is BAD
Old Feb 26, 2007 | 08:13 AM
loner714's Avatar
yea cuz i have a chipped p72 ecu laying around i was gonna test it but i was afraid to. gsr redline is around 8000rpm. when i take it to 7k i hear alot ticking. do i need to rebuild my internals? motor has 215,xxx miles still runs strong but dont like the ticking sound.
Old Feb 26, 2007 | 08:17 AM
iH8RICERZ's Avatar
sounds like your valves need to be adjusted. I wouldn't recommend running a chipped ecu on a stock motor, unless you have it tuned....but you're probably better off running the stock ecu in your situation.
Old Feb 26, 2007 | 08:30 AM
Rikter's Avatar
You keep saying it's chipped...... WHAT kind of chip? Is there a tune on it? Is it just some MOOGEN or VTAK chip off ebay? Do you know ?
-Rik
Old Feb 26, 2007 | 04:54 PM
loner714's Avatar
i dont know what chip it is cuz it came with the civic i bought from a friend a long time ago. all i know is that it was used with a poor man's type r engine.
lovindavtec
Jul 11, 2012 09:38 AM
speed_demon018
Jun 4, 2009 02:05 PM
ryanevansoh
Jan 13, 2009 08:50 PM
kNOwLedGeDA9
Oct 5, 2005 07:03 PM
uniqueX
Nov 29, 2004 10:07 AM
