d16a6 to d15b7 swap
Old Feb 25, 2007 | 09:32 PM
projectpd's Avatar
Default d16a6 to d15b7 swap
Hey i searched the threads and cant find any info ! i need a bit of help from you guys !! my buddy blew his motor in his 1990 civic Si wich has a d16a6 , he has a spare d15b7 from a 1992 Civic Dx . Do you guys think i would run into problems doing this swap ? and could i keep the stock Si ecu to run the d15b7 ? Thanks alot and hope someon will take the time to reply !
Pierre
Old Feb 26, 2007 | 07:26 AM
92_VX_EG's Avatar
Default Re: d16a6 to d15b7 swap (projectpd)
As long as you put everything off the A6 on the B7 it'll be fine and the ECU will work. You'll have to use the wiring harness, dizzy, injectors, alternator, etc... off the A6.
Old Feb 26, 2007 | 09:53 AM
MR.johnson's Avatar
Default Re: d16a6 to d15b7 swap (92_VX_EG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92_VX_EG &raquo;</TD></TR><TR><TD CLASS="quote">As long as you put everything off the A6 on the B7 it'll be fine and the ECU will work. You'll have to use the wiring harness, dizzy, injectors, alternator, etc... off the A6.</TD></TR></TABLE>
yes, use every thing off the a6.
Old Feb 26, 2007 | 10:00 AM
projectpd's Avatar
Default Re: d16a6 to d15b7 swap (MR.johnson)
So for what i understand .. i could use the intake manifold from the d16a6 and distributor and wiring harness and thats it ! right ?
Old Feb 26, 2007 | 11:32 AM
Manga_Spawn's Avatar
You should put the A6 cam into the B7 as well. The A6 cam is more agressive and will give the B7 alittle more power.
Old Feb 27, 2007 | 10:55 AM
projectpd's Avatar
Default Re: (Manga_Spawn)
hey .. yeah but for what i undertood i gotta use a y8 or y7 cam gear !!! and i dont have that !
Old Feb 27, 2007 | 10:57 AM
MR.johnson's Avatar
Default Re: (projectpd)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by projectpd &raquo;</TD></TR><TR><TD CLASS="quote">hey .. yeah but for what i undertood i gotta use a y8 or y7 cam gear !!! and i dont have that !</TD></TR></TABLE>
no you use the a6 cam gear.
Old Oct 15, 2011 | 02:21 PM
brooster's Avatar
I have a 90 civic si with a d16a6 (obd0), the bottom end went in it so i figured i do a swap with a d15b7 (obd1) i had laying in my garage. i have heard that i dont need to change wireing or ecu if i just swap the head from the d16a6 onto the d15b7 block, so i went and bought a new head gasket and timing belt for a (d16a6) to do the swap. than i later relized while searching around the internet that all i have to do is take the intake manifold and distributor off of the d16a6 and put it on the d15b7 head and block and everything will be plug and play ? i need some help i have a week to get the motor back in and running any advice on what i should do ? would be greatly appreciated thanks
Old Oct 15, 2011 | 02:38 PM
grumblemarc's Avatar
The Grumpiest
90 Civic? You're in the wrong forum.
Old Oct 16, 2011 | 12:21 PM
brooster's Avatar
so all you have to do is switch the intake manifold and distributor and drop the motor back in and plug everything back in and should work ? im doing the same swap my d16a6 blew up and i had a spare d15b7 laying around i have a week to get this done and need some info ? would be greatly appreciated
Old Oct 16, 2011 | 02:28 PM
HondaPartsHero's Avatar
Technical Hero
Swap over intake manifold, distributor. You'll also need to swap over the mount from the block in the drivers side to the b7. The fan switch will also have to be wired from the back of the block to the thermostat housing on the b7.
Old Oct 16, 2011 | 02:31 PM
NotAJDMFanBoy's Avatar
Just swap the intake manifold and whatever wiring you need to. You shouldn't change the cam gear, the purpose for swapping that gear on a mini-me swap is to keep everything in time when swapping a newer (96-00) head onto a 95 or older block.
CRXguy_88
11
Mar 1, 2010 03:47 AM
prcivic91
Apr 12, 2007 08:26 AM
PDRIFT86
Apr 11, 2007 09:20 PM
crxnonvtec
Dec 20, 2005 06:14 AM
Civiclized
Nov 17, 2004 03:15 PM
