what type of camshafts can i use with jackson racing supercharger?
Old Feb 25, 2007 | 08:18 PM
ALLMOTOR CRX's Avatar
Default what type of camshafts can i use with jackson racing supercharger?
i want to get a jackson racing supercharger for my gsr motor. but before i do i want to get some info on it.. what type of camshafts can i use turbo cams or can i use for allmotor cams. like the zex 57200 because those are the once i already have or like blox hsl cams? or do i have to get some turbo cams? and also does supercharger give you lots of problems or no? is it worth the hassle and the money what do you guys think?
Old Feb 26, 2007 | 01:09 PM
RICE POLICE SIP's Avatar
Default Re: what type of camshafts can i use with jackson racing supercharger? (ALLMOTOR CRX)
most people will say don't do it and go turbo but it's still fun to be supercharged.. It's just a diff. kinna fun.. But as for the cams I would like to know that too.. I heard Type R cams will be good... Also you'll need the VTEC to kick in earlier...
Old Feb 26, 2007 | 01:11 PM
DaveF's Avatar
Default Re: what type of camshafts can i use with jackson racing supercharger? (RICE POLICE SIP)
any "all motor" cam should work great !
Old Feb 26, 2007 | 02:44 PM
so i can use allmotor cams for supercharger right?what if you want to boost wont that affect the cams?
Old Feb 26, 2007 | 02:50 PM
DaveF's Avatar
Default Re: (ALLMOTOR CRX)
cam gears
Old Feb 26, 2007 | 05:58 PM
Tonyl507's Avatar
Default Re: (dturbocivic)
I remember seeing on here somewhere that GSR cams work well with the JRSC...
Just look at JacksonRacings Website on thier Dyno Sheets for VTEC integras
The GSR puts out more power then the Type-R - both w/ same boost pullys - 6 p.s.i (and the type-r has higher compression...)
Anyway, this is just what i heard... have no experiance hands on with one to tell you for sure...
but, i do know you want something with low overlap, (i think most aggressive NA cams have higher overlap?) - which is no good when ur forceing air into the motor
Old Feb 26, 2007 | 06:01 PM
JDogg's Avatar
Default Re: (Tonyl507)
stock gsr cams made 35hp more than Blox HSL cams.. we put some crower turbo cams in and it felt faster, but we never dyno'd it
Old Feb 26, 2007 | 06:02 PM
sc4dr's Avatar
Turbo cams are not what you want. gsr or itr cams work best. If you wanna switch em up try a gsr intake, and itr exhaust cam. I have run all three variations, and my motor liked the itr cams the best.
Old Feb 26, 2007 | 06:35 PM
92DAturboteg's Avatar
Default Re: (sc4dr)
I always thought that supercharges usually don't like alot of overlap. In which case a turbo cam with more lift and less duration should keep the cyllinder pressures high yeilding you more mid end power. Then again jrsc's make plenty of mid end so maybe more top end is what your looking for. I don't know for sure but I would like to.
Old Feb 27, 2007 | 10:42 AM
yeah im not sure what type of cams to use either allmotor cams with high lift or keep my stock gsr cams thats what i have right now.. my friend has a supercharged gsr integra his got type r cams in there and vtec hits pretty hard with a big pull.
Old Feb 27, 2007 | 11:08 AM
JDogg's Avatar
keep the gsr cams. bit NA cams will cost you a good 30hp
Old Feb 27, 2007 | 11:17 AM
any prove of what you are saying dyno sheets? one more thing is it hard to install a supercharger or would i be able to do it.. what and what goes connect to it? any hard things such as wires and stuff?..,
Old Feb 27, 2007 | 12:16 PM
njn63's Avatar
GSR Intake cam doesn't gain any peak HP over the Type R but will make more power in other parts of the power band. I don't have a sheet but there is someone on another board that dynoed them basically back to back on his 270whp JRSC B18C5.
Old Feb 27, 2007 | 03:10 PM
Default Re: (njn63)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by njn63 &raquo;</TD></TR><TR><TD CLASS="quote">GSR Intake cam doesn't gain any peak HP over the Type R but will make more power in other parts of the power band. I don't have a sheet but there is someone on another board that dynoed them basically back to back on his 270whp JRSC B18C5.</TD></TR></TABLE>
How many pounds was that on and what was his setup?
Old Feb 27, 2007 | 04:35 PM
sc4dr's Avatar
Default Re: (RICE POLICE SIP)
He was running around 10 psi, on a b18c5 and an lHT intercooler. He gained a little power through the middle using the gsr in. itr ex.
Old Feb 27, 2007 | 04:37 PM
sc4dr's Avatar
Default Re: (sc4dr)
I made 303 whp using the gsr in. itr ex. cam combo on my jrsc setup.
Old Feb 27, 2007 | 04:55 PM
you made 303 but on a stock gsr with stock pistons? where you boostin the supercharger?
Old Feb 27, 2007 | 04:59 PM
sc4dr's Avatar
Not a stock motor, just stock cams. It was making 14.8 psi with 185deg intake temps(for anyone curious). It was also a Endyn modded blower.
Old Feb 27, 2007 | 05:12 PM
njn63's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RICE POLICE SIP &raquo;</TD></TR><TR><TD CLASS="quote">
How many pounds was that on and what was his setup?</TD></TR></TABLE>
http://www.tuner-junction.com/....html -when he first put it in.
http://www.tuner-junction.com/....html There is the post about when he went back to the dyno with the GSR intake cam. As you can see.. didn't get to fully test it and now he's going 2.1L.
Old Feb 27, 2007 | 05:48 PM
damn nice numbers so what you recommend to do is run intake gsr cam and type r on exhaust right? would that be a good setup power to the wheel or no?
Old Feb 27, 2007 | 06:14 PM
sc4dr's Avatar
I think thats what were saying.
Old Feb 28, 2007 | 08:59 AM
thanks guys what about connecting a supercharger is it hard?
Old Feb 28, 2007 | 10:41 AM
HT Chaplain's Avatar
Loved
i always heard the stock ones are best
Old Feb 28, 2007 | 04:01 PM
sc4dr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ALLMOTOR CRX &raquo;</TD></TR><TR><TD CLASS="quote">thanks guys what about connecting a supercharger is it hard?</TD></TR></TABLE>
If you have mechanical experience it's not hard(just a little cramped). The only way to learn is to just do it.
Old Feb 28, 2007 | 05:09 PM
turboedc2's Avatar
Default Re: (sc4dr)
They told the blox spec b's are good...
