Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
So the DIY Foglight Fix works well!
Old Feb 25, 2007 | 06:37 PM
Demonis's Avatar
Default So the DIY Foglight Fix works well!
Here's how mine went:
Went to Home Depot, bought the lexan, a blade to cut plastics for my saw, and some high temp adhesive.
(click for larger views)
First: Off comes bumper
Then: Out comes lens and OEM adhesive
Then: After cutting and much grinding into perfect shape, applying adhesive, viola!
...YES I KNOW the car is filthy, friday it rained, and yesterday we had a dust storm all day long. SO, i had a choice today.... wash the car, or fix the foglight.
Old Feb 25, 2007 | 06:40 PM
Type X's Avatar
Default Re: So the DIY Foglight Fix works well! (Demonis)
nice
i was just talking about this to Nomar to protect his retro
Old Feb 25, 2007 | 06:41 PM
Demonis's Avatar
Wasn't hard, took a couple hours because of the grinding, i had to make sure it was perfect. But the cutting and placing only too a few minutes each.
Old Feb 26, 2007 | 12:48 PM
devani's Avatar
nice fog...good diy..
Old Feb 26, 2007 | 06:52 PM
Nomar06's Avatar
Default Re: So the DIY Foglight Fix works well! (devani)
Yeah, might have to do this soon. My lenses look like junk after 11k miles.
Old Feb 26, 2007 | 06:59 PM
FERIOkid's Avatar
Default Re: So the DIY Foglight Fix works well! (Nomar06)
not sure if you guys have seen this but coresportusa.com sells a laminex adhesive protector for the foglights that is already cut to fit the coupe/sedan fogs. They are $25 and you can get them in clear,blue,yellow or tinted black
here is a link incase anybody is interested(I just picked up a set to protect my fogs and will have a write-up soon) :
SEDAN FOGLIGHTS : http://www.corsportusa.com/sto...=1444
COUPE FOGLIGHTS : http://www.corsportusa.com/sto...=1445
Old Feb 26, 2007 | 07:19 PM
Type X's Avatar
Default Re: So the DIY Foglight Fix works well! (FERIOkid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FERIOkid &raquo;</TD></TR><TR><TD CLASS="quote">not sure if you guys have seen this but coresportusa.com sells a laminex adhesive protector for the foglights that is already cut to fit the coupe/sedan fogs. They are $25 and you can get them in clear,blue,yellow or tinted black
COUPE FOGLIGHTS : http://www.corsportusa.com/sto...=1445</TD></TR></TABLE>
those kits get burnt up from the heat, and wont protect from a rock that would break the lense.
Old Feb 26, 2007 | 07:20 PM
FERIOkid's Avatar
Default Re: So the DIY Foglight Fix works well! (Type X)
it says that they cut the size down due to the heat that comes off the foglights
***Due to the high temp output from these fogs, the kit will be appx 1/8" smaller than the lens to allow for heat dissipation. Also, to prevent burning, turn fog lights off if vehicle will be stationary for more than 15 minutes.***
Old Feb 28, 2007 | 05:07 AM
Demonis's Avatar
lets see... $25 for films that wont protect from broken glass... or $25 for near indestructable fog lenses... HMMM
Old Feb 28, 2007 | 05:36 AM
jonebone's Avatar
Video Game Collector
Yeah the only reason I have not purchased fog lights for my coupe is because they are easily broken. After seeing this, I may have to reconsider...
Old Feb 28, 2007 | 01:50 PM
FERIOkid's Avatar
Default Re: (Demonis)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Demonis &raquo;</TD></TR><TR><TD CLASS="quote">lets see... $25 for films that wont protect from broken glass... or $25 for near indestructable fog lenses... HMMM</TD></TR></TABLE>
I like yellow and my warantee that covers my foglights. Honda can replace them 1,000 times for all I care
Old Feb 28, 2007 | 01:53 PM
hotrodmike's Avatar
I did my fog lights over with Lexan well one of them. It was fairly quick and easy to do. Did I mention Cheap as well.
Old Feb 28, 2007 | 02:16 PM
Demonis's Avatar
I duno what dealer you went to, but none around here replace the fogs... getting them broke is considered road hazard and only covered by insurance.
Old Feb 28, 2007 | 02:24 PM
honda06si's Avatar
so wait. what was wrong with your fog lights?
Old Feb 28, 2007 | 05:34 PM
FERIOkid's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Demonis &raquo;</TD></TR><TR><TD CLASS="quote">I duno what dealer you went to, but none around here replace the fogs... getting them broke is considered road hazard and only covered by insurance.</TD></TR></TABLE>
my dealer covers them under my 4 year 45,000 mile bumper to bumper warantee
Old Mar 1, 2007 | 05:28 AM
Demonis's Avatar
you got lucky then, i called three dealers, all told me it was road hazard, like paint chips.
Old Mar 2, 2007 | 01:47 PM
IT GUY's Avatar
Default Re: (FERIOkid)
my dealer covers them under my 4 year 45,000 mile bumper to bumper warantee</TD></TR></TABLE>
They'll cover failure for 4 years, but like Demonis said if they crack or chip it might as well be body damage. Dealer won't fix them. All Dealers cover parts malfunction, but not damage / wear and tear.
Old Mar 2, 2007 | 11:32 PM
JeShUa's Avatar
how hard was grinding it?? what did you use to get it the perfect shape ;]?
Old Mar 3, 2007 | 08:36 AM
Demonis's Avatar
Well like it shows in the DIY on club rsx, you trace the fog lamps oval onto the lexan then you cut it out, and you have to grind down the rest, basically i just kept grinding and then trying to fit it into the lamp until i had the right shape. Luckily I thought ahead and traced my finished product onto the lexan so next time (the other lamp) i wont have to grind so much.
The lexan grinds really easy, if you have a decent grinder. Like shaving butter.
Old Mar 8, 2007 | 08:16 AM
Type X's Avatar
added to DIY faq.
Old Mar 8, 2007 | 08:21 AM
06blaksi's Avatar
Sweet........I have a chip in mine as we speak and I have Lexan at work
Old Apr 18, 2007 | 10:49 AM
N4me (06civicsi)'s Avatar
wow i just called my local dealer and asked how much a replacement fog light lense is they`re charging 145 per lense...now is it just me or does that sound extremely expensive ? anyone know where 2 get cheap replacement lenses? and a question to OP did u use a glass lense for u`r fix or is that just lexan?
Old Apr 18, 2007 | 11:08 AM
Type X's Avatar
Default Re: (N4me (06civicsi))
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by N4me (06civicsi) &raquo;</TD></TR><TR><TD CLASS="quote">wow i just called my local dealer and asked how much a replacement fog light lense is they`re charging 145 per lense...now is it just me or does that sound extremely expensive ? anyone know where 2 get cheap replacement lenses? and a question to OP did u use a glass lense for u`r fix or is that just lexan?</TD></TR></TABLE>
http://www.hondaautomotiveparts.com
Old Apr 18, 2007 | 11:13 AM
its cheaper just 2 buy the whole fixture on that site...thnx
Old Apr 18, 2007 | 11:21 AM
Type X's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by N4me (06civicsi) &raquo;</TD></TR><TR><TD CLASS="quote">its cheaper just 2 buy the whole fixture on that site...thnx</TD></TR></TABLE>
and knowing is half the battle.
