im sure someone knows what this is
Old Feb 25, 2007 | 05:11 PM
love_5gen's Avatar
Default need help with 95 civic d16z6
ok sometimes when i go to start my car it just wont eveything turns over the motor just wont get fuel and when it first starts it sounds like its starving for fuel but if i cameback an hour later it starts rtight up so im thinking maybe fuel pump but someone said something about they had the same problem and it was some kind of realy swicth
thanks for ne help
Old Feb 25, 2007 | 05:20 PM
egb16pg's Avatar
Default Re: need help with 95 civic d16z6 (love_5gen)
i think you should reread what you wrote first.
Old Feb 25, 2007 | 05:26 PM
MR.johnson's Avatar
Default Re: need help with 95 civic d16z6 (egb16pg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by egb16pg &raquo;</TD></TR><TR><TD CLASS="quote">i think you should reread what you wrote first.</TD></TR></TABLE>
lol yeah.
Old Feb 25, 2007 | 05:36 PM
HCJDM1's Avatar
Default Re: need help with 95 civic d16z6 (MR.johnson)
x3
but i think you mean that when you first go to start up your car it wont start ? you come back and hour and it will start ?
right ?
well if so i had the same problem ...it was gay .. i couldnt figure it out .. and nor could my mechanic ... we still havent figured it out . but i replaced the plugs . and the old ones were fine but now it starts fine . really wierd .
but i would say change your fule filter .. check your injectors ...and change your plugs and wires for ***** and giggles .
Old Feb 25, 2007 | 06:57 PM
love_5gen's Avatar
Default Re: need help with 95 civic d16z6 (HCJDM1)
yeah sry about that i was in a diff state of mind but yeah thats what i meant
Old Feb 25, 2007 | 07:01 PM
B16B_coupe's Avatar
HRD PKR
change ur fuel filter.. check ur fuel pressure..
Old Feb 25, 2007 | 07:04 PM
Libertariat's Avatar
Ek Forever y0!
Default Re: need help with 95 civic d16z6 (B16B_coupe)
replace the relay, and the filter. Two easy fixes that will get ruled out.
CHeck for spark, and listen for pump priming when you turn the keyy to acc before starting.
Old Feb 25, 2007 | 07:15 PM
love_5gen's Avatar
Default Re: need help with 95 civic d16z6 (ek forever guy)
yeah it is i was listning to it earlier its weird casue it only does it like once a month but after it starts it runs perfect
Old Feb 25, 2007 | 07:17 PM
love_5gen's Avatar
oh btw ne one wanna let me know why i cant change my avatar thing
Old Feb 25, 2007 | 07:35 PM
ghettoSi's Avatar
she's cheating on you
probably cuz your in trial
Old Feb 25, 2007 | 09:12 PM
ke98248's Avatar
Default Re: need help with 95 civic d16z6 (ghettoSi)
Please proof-read what you type before you post.
Old Feb 25, 2007 | 11:22 PM
yoej8's Avatar
Default Re: need help with 95 civic d16z6 (ke98248)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ke98248 &raquo;</TD></TR><TR><TD CLASS="quote">Please proof-read what you type before you post.</TD></TR></TABLE>
Then after that, rewrite it using the edit button.
Anyway, does it sound like it has trouble starting cause if so, you battery could be dying or alternator is bad causing your battery to go bad.
It probably starts up right away an hour later because it got a chance to "rest".
is3oo
Sep 8, 2008 01:07 AM
SpoolinEK
Dec 10, 2003 02:28 PM
ITR.#1446
Oct 28, 2003 11:19 AM
B16Ej1
Jun 4, 2003 04:58 PM
