help with ITR sway install EG - end link alignment
I am trying to install an ITR sway on my 92 civic si - usdm itr sway and BSQ Kit. I am using DC endlinks and I cannot get the endlinks to line up at all, the angle is so bad I can't even get the endlink bolt into the the LCA at all. I must be missing something.
Modified by deckster333 at 2:28 AM 2/26/2007
Modified by deckster333 at 4:01 AM 2/26/2007
yes i just found out that a few people had problems with the omni lca when using DC endlinks. Has anyone had good results with EK or EM endlinks, or possibly any aftermarket endlinks?
when you said BSQ kit did you mean beaks kit? i only ask because i dont see a beaks kit on there but a metal plate.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by deckster333 »</TD></TR><TR><TD CLASS="quote">or maybe try adding washers? has anyone had this problem?</TD></TR></TABLE>
yea others had to add washer with the omni setup... i would sell those and get gsr lca's
and whats that rust looking stuff by poly inserts?
omni = cheap upon purchase; but more trouble as you put it on the car
dam that's crap, the reason I bought these is because my stock lcas didn't have a place for a sway. I would rather not use washers. Has anyone tried using a different set of endlinks?
the place where the sway bar meets is in the wrong position. i think you will need some type r lca's because the sway bar mounting points are in a different location.
It was recommended that you use lcas for a DC, which these are. I guess I would have to use stock dc lcas? Has anyone tried endlinks from a 99 SI?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by verycleanhatch »</TD></TR><TR><TD CLASS="quote">the place where the sway bar meets is in the wrong position. i think you will need some type r lca's because the sway bar mounting points are in a different location.</TD></TR></TABLE>
NO!
I have omni LCA's as well (should have gone with something diffrent, but that's beside the point). I used Blox endlinks with no problems. Washers could work, but not something i wanted to try...
The Blox endlinks are a nice product. I think i got them from King motorsports for ~$40 shipped.
NO!
ok so you think blox adjustable endlinks would work for my application? eg+omni lca+type r sway+BSQ kit? Can someone confirm this thanks.
I know it will work. Seeing as i have a DC2 (essentially the same subframe) with sway/omni LCA's (reinforcement kit will not change fitment)
But anyways, bump for your confirmation.. I wish i knew about the terrible omni LCA to sway fitment before i bought them.
GetawayInMoscow
Suspension & Brakes
Aug 5, 2005 12:56 PM
J.P. 4rm The dPk*
Nov 18, 2002 10:58 AM
