obd2 gsr engine into 94 civic vtec IAB wiring help (butterflies)
Old Feb 25, 2007 | 04:22 PM
3ghandles's Avatar
Default obd2 gsr engine into 94 civic vtec IAB wiring help (butterflies)
okay guys i got the rest of of the vtec hooked up i usually have obd 1 swaps and i wire vtec fine with no problems. i got this obd 2 and i noticed the wire colors on the secondaries wires are diff. can somebody show me a diagram of the vtec wiring. i've been searching but i cant find this. also they talk about moving the wire from a20 to a17. i dunno. need help. thanks in advance.
Old Feb 25, 2007 | 06:39 PM
3ghandles's Avatar
Default Re: obd2 gsr engine into 94 civic vtec IAB wiring help (3ghandles)
anybody
Old Feb 26, 2007 | 01:28 PM
3ghandles's Avatar
LAST TIME I CHECKED THERE WERE PLENTY OF SWAPS AROUND HERE.....HMM
Old Feb 26, 2007 | 05:38 PM
HondaPartsHero's Avatar
Technical Hero
Default Re: (3ghandles)
run the top wire coming out of the plug (closest to the clip) to the ECU pin above, the bottom wire needs to run to a switched 12V
Old Feb 26, 2007 | 06:25 PM
3ghandles's Avatar
thanks for the respond what i seen that write up before and its for a obd 1 engine. i have a obd 2 engine . i need the colors to the wires of the butterflies.because i noticed on the obd 2 they slightly changed
Old Feb 27, 2007 | 03:26 AM
3ghandles's Avatar
this is so confusing...i just need a obd 2 gsr hybrid swap owner to clear this up for me.....from what i understand. obd 1 p72 iab uses a NEGATIVE signal to activate
the obd 2 p72 uses a POSITIVE SIGNAL TO ACTIVATE. also like i said the wires on the secondaries are not the same color....could somebody please comeup and clear this up for me....thanks..
Old Feb 27, 2007 | 12:41 PM
Technical Hero
unless the IAB itself is different the wire color want matter
Old Sep 16, 2008 | 08:03 AM
MugenNSX's Avatar
Default Re: (HondaPartsHero)
Bump...Because i'm goin thru the same issues. Can any body confirm this?
Old Sep 16, 2008 | 02:42 PM
civic95hbvtec's Avatar
Buy a cheap Blox intake mani, i buy S2 but then you dont have to worry about it.
Looks better and flows better also, i had to
retune my civic after i installed the S2 pro-series it was leaning me out.
Old Sep 26, 2008 | 02:42 PM
lilo_goki's Avatar
like civic95bvtec said, just get a skunk2 pro series manifold and your good to go. screw the iab and egr.
215HPLSVTEC
Mar 19, 2008 09:58 AM
3ghandles
Feb 26, 2007 01:27 PM
ls weez
Jun 10, 2006 09:53 PM
ilovemyb16a
May 18, 2006 12:58 PM
casualxboi
Oct 9, 2001 06:30 AM
