ecu question
Old Feb 25, 2007 | 04:16 PM
BlueRex1020's Avatar
Default ecu question
hey guys, i just picked up a p06 ecu chiped n programed with chrome...i was wondering if this ecu would work fine with an LS swap im planing to do in the spring?
Old Feb 25, 2007 | 06:50 PM
Default Re: ecu question (BlueRex1020)
anyone?
Old Feb 26, 2007 | 03:37 PM
bump
Old Feb 26, 2007 | 07:02 PM
no one?
Old Feb 27, 2007 | 02:36 PM
hellow? can anyone help me out?
Old Feb 27, 2007 | 02:52 PM
janz3n's Avatar
Default Re: (BlueRex1020)
im not really good with this stuff but isnt chrome for tuning? so im gonna guess it will run the car(if its the right ecu for the engine) but might not run it very well. an example.. maybe the ecu is programed for running a turbo.
crx_si-r's Avatar
wat kind of swap. and y not just use the PR4?
Old Feb 27, 2007 | 08:28 PM
Default Re: (crx_si-r)
for an ls swap...i bought the p06 of a friend of mine who had it lying around n he told me it was chiped n tuned with chrome....i think he ran a stock single with it n then chaged to a p28 when he did his ls/vtec in order tu run vtec....n i was converting my rex to obd1 so i needed an obd1 ecu anyway n he gave me a good deal. my question is, if people use p28s which come on d16z6's tu run gsr's n ls/vtec set ups n so on, would it be an issue if i used this p06 which came out of a d15b7 to run an ls?
Old Feb 28, 2007 | 01:45 AM
crx_si-r's Avatar
yes it would be an issue, unless ur ecu which is supposed to run a single cam motor has been chipped to run a dohc motor. i believe its mainly done to bypass the knock sensor sincse P28's dont require a knock sensor.
Old Feb 28, 2007 | 02:39 AM
4thgenhtch's Avatar
You will need to get it reprogramed to LS Specs.. Most anyone can do it w/ a burner I can send you a new chip with proper maps cheap if ya cant find anyone local
Old Feb 28, 2007 | 06:05 AM
Targa250R's Avatar
be professional
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueRex1020 &raquo;</TD></TR><TR><TD CLASS="quote">hey guys, i just picked up a p06 ecu chiped n programed with chrome...i was wondering if this ecu would work fine with an LS swap im planing to do in the spring?</TD></TR></TABLE>
If it hasn't already, the ECU has to be reprogrammed through Crome with a PR4, P74, or P75 program to run properly.
nolanator6
Apr 4, 2011 04:56 PM
chap2556
Jan 26, 2009 12:36 PM
superboy
Sep 14, 2003 10:30 AM
Mr. UnderHill
Aug 20, 2003 11:34 AM
