Better gas mileage
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pr0honda »</TD></TR><TR><TD CLASS="quote">tape an egg underneath your gas pedal... the gains will be amazing.....
LOL!....To BETTER answer the op's question, I heard that higher compression usually means better gas mileage b/c it burns the gas more efficiently also if you get a better tune. So what this means is faster car and better, if not the same mpg! Also breather mods like I/H/E will help. These are some things I have heard and read but not tried myself.
-Moh
</TD></TR></TABLE>LOL!....To BETTER answer the op's question, I heard that higher compression usually means better gas mileage b/c it burns the gas more efficiently also if you get a better tune. So what this means is faster car and better, if not the same mpg! Also breather mods like I/H/E will help. These are some things I have heard and read but not tried myself.
-Moh
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hamadiscool »</TD></TR><TR><TD CLASS="quote">
-Moh</TD></TR></TABLE>
well when you add compression you normally need to add fuel.. if you raise compression you will need to run better fuel..
the reason for my smart *** answer is cause he posted a very vague question and from the information he gave me thats about all i could say..
just learn to keep your foot off the floor and you will get better gas mileage..
tune up = more efficient engine = better mpg
lighter car = easier acceleration = better mpg
tuning = better fuel maps = better mpg
keeping your right foot away from the firewall = better mpg
there are many many ways to get better mpg, what are you considering bad mpg and what is our setup?
If you have a wideband and something to tune with you can lean out your part throttle maps a bit, and advance your part throttle IGN timing. There are some good posts on PGMFI.org on this subject try there.
civic_driver
Sep 25, 2005 11:43 PM
