Just did a compression test today? What you guys think
Old Feb 25, 2007 | 11:05 AM
yan_david's Avatar
Default Just did a compression test today? What you guys think
Hey H-T members,
I just finish my compression test today. What you guys think? I was looking for the psi range on the manual but I couldn't find it. This was perform on a 2000 Honda Civic SI B16A2. with roughly 83,000 miles. Cold temp, WOT, 5 crank, anti-sieze the tread, analog compression test meter.
Cyl#1 Cyl#2 Cyl#3 Cyl#4
195 197 197 195
Thanks
Old Feb 25, 2007 | 11:07 AM
Eran's Avatar
HT White Ops
That's pretty solid.
Old Feb 25, 2007 | 11:08 AM
pennies_hatchie's Avatar
Default Re: (Eran)
its all about consistency
Old Feb 25, 2007 | 11:24 AM
na+b18c_hatch's Avatar
looks pretty damn great for 83,000 miles! boost that ****
Old Feb 25, 2007 | 11:27 AM
. a d a m's Avatar
Default Re: Just did a compression test today? What you guys think (yan_david)
looks good to me
Old Feb 25, 2007 | 03:26 PM
.Kevin.'s Avatar
Default Re: Just did a compression test today? What you guys think (. a d a m)
Next time make sure the motor is up to operating temp before you perform the test.
You should be right around 200 and you are so the motor is strong
Old Feb 25, 2007 | 04:02 PM
Si_chRis's Avatar
Default Re: Just did a compression test today? What you guys think (Ep_Kevin)
My SI is at about 76k and I had around the same numbers as you the last time I did a compression check.
Old Feb 25, 2007 | 04:24 PM
chrischaks's Avatar
nice! boost it! btw anyone go to the show today in china town?
Old Feb 26, 2007 | 08:08 AM
yan_david's Avatar
do you guys think that I would have bent valves? there ticking but I already had a valve adjustment done. I heard that it could be injectors. is there a way to check? thanks
efking1985
Jul 26, 2010 02:13 PM
integraRS-T
Jul 3, 2007 07:45 PM
guero2craze
May 8, 2007 09:15 PM
hybrid1990crx
Sep 13, 2005 05:36 PM
InLimbo87
Jun 22, 2004 07:54 PM
