2.5" custom NON-mandrel bent exhaust piping?
Old May 21, 2002 | 07:57 AM
eTec's Avatar
Default 2.5" custom NON-mandrel bent exhaust piping?
I know that mandrel bent is the way to go for better flow but there aren't any shops locally here with a mandrel bending machine. So what difference if any would a custom crimp piping opposed as to mandrel bent make? Are we talking 1-2 horsepower? I would like to compliment my JDM header and 2.5" testpipe with a full 2.5" exhaust as well. There is a shop down the street from me that could do the 2.5" piping and everything for $100 and he says that the crimp style won't make that much of a diff.
Old May 21, 2002 | 08:35 AM
00MRSi's Avatar
Default Re: 2.5" custom NON-mandrel bent exhaust piping? (eTec)
I wouldn't get it. Totally defeats the purpose, especially since you have a JDM 2.5" collector/header. If you can't get custom mandrel bent, than just get a good aftermarket exhaust. They are mostly 60mm piping (aprx. 2.38") and flow pretty well. You can get a reducer from SMSP to ease the transition from the 2.5" to 2.38" piping. An N1 style system will flow better. Its worth the $400-$500 for the mandrel bent aftermarket catback.
Old May 21, 2002 | 09:04 AM
TurboSohc's Avatar
you got mandrel/crushed you make the choice
Old May 21, 2002 | 09:12 AM
HybridHatchC1's Avatar
Default Re: 2.5" custom NON-mandrel bent exhaust piping? (TurboSohc)
its not worth it at that dia, i am tired of these people reading super street and talking ****, do a flow test on 2.5 mandrel and crush, i bet you will be suprized by the results, there not much difference at all extremely minimal, i don't care if the people come here and flame me but i know i know the next exhaust i buy it gonna be about $400 cheap then my thermal and it going to produce more mid-high range power.
Old May 21, 2002 | 09:41 AM
Fillmore Slim's Avatar
There's a shop that sells mandrel bent corners but i cant remember the name. Anybody else know what im talking about ?? You could just buy the corners and take them to the shop and have them weld it up and it will still save you some money.
Old May 21, 2002 | 09:44 AM
eTec's Avatar
Default Re: 2.5" custom NON-mandrel bent exhaust piping? (Civ-JDM)
So your saying there is a minimal difference? I've already got a N1 catback so I'm curious as to whether or not the 2.5" crimp piping would do any harm.
I know the census around here favors mandrel bent piping but this only compared to the stock, what 2"?...crush piping. You add another half of inch to that, even though it has crush bends the bigger piping has to help somehow. I have to agree with Civ-JDM, the dif has to be minimal.
Old May 21, 2002 | 09:47 AM
eTec's Avatar
Default Re: 2.5" custom NON-mandrel bent exhaust piping? (Fillmore Slim)
Actually I believe you end up spending more because not only do have to buy the pieces you have to have someone weld all that togheter.
Old May 21, 2002 | 10:07 AM
Not what i have seen. Its dirt cheap to have it all welded up plus you have an exhaust to your specs. You only buy the corners from a place like://www.burnsstainless.com/ and use the shops piping for the rest. its a cheaper alternative. whatever you like or can afford, I talk smack all the time about getting a custom exhaust but would probably just buy a mandrel bent cat back for my next one.
Old May 21, 2002 | 10:27 AM
00MRSi's Avatar
You already have an N1 catback? Then why waste your time and money on a custom piece? Unless you have serious mods, you're N1 catback should be more than adequate to do the job. Get the SMSP reducer if you want it.
Old May 21, 2002 | 11:10 AM
SECRET AP1's Avatar
i don't know what car you drive, but OEM exhausts are mandrel bent. the difference between a crush and mandrel bend depends on the angle that you are bending it. crush bending forces the flow the taper causing a significant number of backpressure points when you have multiple bends like this. futhermore, 90º bends already reduce flow by a quarter of what it would be in a straight pipe.
IMHO, if you're going to run with altezza lights, blacked out headlights, bright yellow racing stripe, tenzo/revo/cheapcrap seats, short ram POS intake, OBX headers, etc etc... then by all means, keep building that low-budget empire of yours upon that car. but just because you can't find anyone locally to do mandrel bending for you, dont go and convince yourself that crush bending makes a "minimal" difference.
[Modified by JDM EG6, 8:11 PM 5/21/2002]
Old May 21, 2002 | 12:16 PM
Default Re: 2.5" custom NON-mandrel bent exhaust piping? (JDM EG6)
ok enough of the altezza tails,obx header, and yellow racing stripe we dont need to know about your pos car, but we do need to know whether or not you have flow tested 2.5 in pipe in mandrel and crush bent form, because i have, and i will tell you agian its a minimal difference.
[Modified by Civ-JDM, 9:17 PM 5/21/2002]
Old May 21, 2002 | 12:18 PM
SkyeC's Avatar
Boba Connoisseur
25 Year Member
I had 2.5" crush bent for one day. It felt like ****.
Went back to 60mm GReddy SP. My favorite exhaust for the EH3 ever made.
Old May 21, 2002 | 01:45 PM
EddieHatchBlack's Avatar
Default Re: 2.5" custom NON-mandrel bent exhaust piping? (SkyeC)
JC Whitney sells mandrel bends.. its like less than 10 bucks or soemthing
QUESTION:
If i were to buy mandrel bent corners for my exhaust, what kinda corners would i need??? 45 degree, 90 degree?? and how many...this is for a 97 ciivc hatch.
Eddie
Old May 21, 2002 | 01:48 PM
eTec's Avatar
Don't just say it felt like **** without saying why! What motor mods did you have? Just checking cause I'm sure you know unless your pushing good volume of course its probably gonna feel like ****.
Old May 21, 2002 | 01:57 PM
pLaYbOi's Avatar
New User
lets b honest here..
going up in the size up exhaust piping for honda or even put on a header wont make much of a difference on honda/acura cars..
but in the long run...a mandrel bent is worth it..u have better flow...a bitsy itsy more power...so its worth it..
well...adding an exhaust only make minimal difference from stock..
so u cant really compare a crushed n a mandrel..
imo...100 bucks for a mandrel custom piping is worth it....go for it..
Old May 21, 2002 | 02:00 PM
eTec's Avatar
ummm...I'm looking at my stock Si exhaust now and those bends don't look like no freaking mandrel bent to me. And what the hell is all that about altezzas and **** man! Wasted space for this possibly informative thread.
s13hero
Nov 24, 2010 05:21 AM
FlewByU352
Sep 14, 2009 06:44 PM
Rory Breaker
Dec 11, 2002 10:43 AM
Ibuprofen
Oct 29, 2001 04:38 AM
boost killz
Sep 27, 2001 05:26 PM
