car cranking but not starting.
Old Feb 25, 2007 | 07:13 AM
Pr0ject93hb's Avatar
Default car cranking but not starting.
so last night my 93 eg didnt want to start. its been showing signs of a slight starting problem starting to build up. on friday it did not want to start but i finally got it going. and then on saturday afternoon i remote started it and it would start and then die. but if i started it by key it would start as long as i got on the gas as soon as i turned it over.
so at first i was thinkin my fuel filter could be clogged, but now im leaning towards fuel pump because on top of my fuel filter i have a fuel pressure gauge and i was thinking, correct me if im wrong, that as soon as i turn the key into the second position so that everything comes on and the fuel pump primes, i should be getting pressure to the gauge right? cause im getting nothing.
so my first thing to check was the fuses but there isnt any fuses labeled fuel pump. a friend said that civics dont have fuel pump fuses. is this true?
so...any ideas would be very much appreciated. this is on my lsvtec set up btw
Old Feb 25, 2007 | 07:15 AM
Throwdown's Avatar
From: CAPITAL CITY Tallahassee D.S., Florida, U.S.A
Default Re: car cranking but not starting. (Pr0ject93hb)
fuel issue? did you try the main relay?
Old Feb 25, 2007 | 07:30 AM
Default Re: car cranking but not starting. (Throwdown)
i havent really tried anything yet. i'll try that though. is that a fuse or what?
Old Feb 25, 2007 | 08:23 AM
bump
Old Feb 25, 2007 | 08:34 AM
rarejdmkid's Avatar
hmm.. i would say.. do the basics.. like check if you have spark.. fuel.. ect.. if it cranks but doesnt start.. replace crank/cam sensor? but check the basics before doing so.. dont wanna lead you in the wrong direction..
anthony01
Dec 15, 2012 06:15 PM
JDMFEVER
Nov 8, 2007 03:18 AM
nicko360
15
Jan 17, 2007 06:22 PM
ewing86
Oct 20, 2004 04:35 PM
