valve to piston clearance?
Old Feb 25, 2007 | 05:52 AM
ys1civicsi's Avatar
Default valve to piston clearance?
alright my setup is a ls/vtec with usdm type-r pistons and a built b16 head, and the head has been milled .020 of an inch now my question is will my valve to piston clearance be cool if i plan to run a stage 2 blocks type -B cam or will i have issues let me know thanks guys
Old Feb 25, 2007 | 06:32 AM
1 2 NV's Avatar
Default Re: valve to piston clearance? (ys1civicsi)
hey, instead of being spoon fed why dont you do some damn research instead of trusting somebody on the net.
Old Feb 25, 2007 | 10:23 AM
GarageAlchemist
Guest
Posts: n/a
Default Re: valve to piston clearance? (1 2 NV)
what he means to say is you should clay the engine of course
Old Feb 25, 2007 | 11:31 AM
hopware's Avatar
It's not quite that simple. There are too many variables in play. If you do not verify the clearances for yourself, you risk the wrath of Darwin. Seek out the knowledge you need, if you don't know how. Learning how to assemble an engine correctly, is a lot less painful, and way more satisfying, than standing on the roadside, wondering how that hole got in your block.
hondathan
K Series
May 19, 2014 08:13 PM
Spawne32
Dec 21, 2010 08:47 PM
ls_bitik
Oct 17, 2007 09:59 PM
5_Lug_B
Sep 19, 2007 04:55 AM
HotRodTeg
Nov 17, 2003 06:26 AM
