deck is on, speakers wired up, but no sound?
Old Feb 24, 2007 | 10:41 PM
Nguyenv25's Avatar
Default deck is on, speakers wired up, but no sound?
ight so i put on some tein springs in order to do that with my hatch since my speaker towers are in the way. i have to remove my speakers to get to my strut towers. so i took off my rear 6x9 speakers that i have ghetto rigged. after i have gotten everything back together when i was done. my sound does not work anymore. my deck is still able to turn on, but there is no sound comming from any of my speakers. im thinking the speaker wires that i ghetto rigged for each speaker touched and caused a short somewhere. im talking about the positive and negative wires for one speaker. what fuse would i check for this type of situation?
Old Feb 24, 2007 | 10:45 PM
Honda_ThuGZ's Avatar
Default Re: deck is on, speakers wired up, but no sound? (Nguyenv25)
have u tried another head unit
Old Feb 25, 2007 | 12:30 AM
whizdumb's Avatar
Default Re: deck is on, speakers wired up, but no sound? (Honda_ThuGZ)
Make sure there are no speaker wires grounding out -- make sure they are connected to the speaker terminals and not "floating around" touching the chassis or anything. If they are all connected like they are supposed to be, make sure none of the speakers are blown and that none of the wiring is pinched/cut.
If any speaker wires are touching a ground it would cause this to happen. Try cutting the wires on the back of the deck going to each speaker one by one until it starts playing the rest of them and you've found the problem speaker.
Old Feb 25, 2007 | 06:18 AM
B18C_EJ8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">so i took off my rear 6x9 speakers that i have ghetto rigged. </TD></TR></TABLE>
Properly install them and come back and talk to us.
Old Feb 25, 2007 | 12:15 PM
wrx-killer-Sti-eater's Avatar
From: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
Default Re: (B18C_EJ8)
^^^^^^ second that.
Old Feb 25, 2007 | 01:49 PM
fcm's Avatar
fcm
Old Fart
Ditto the above.
PS, what exactly do you mean "ghetto rigged", and what is the MM&Y of your car? 94
Old Feb 25, 2007 | 09:07 PM
Nguyenv25's Avatar
99 hb dx, i checked my wires again and i found out that part of the wire was stuck under the strut tower bolt onto the chassis. the wires were torn up by that. by "ghetto rigged" i mean spice connect and taping. thanks for your help
kaivorth
Audio / Security / Video
Dec 13, 2016 01:43 PM
@5200
Mar 18, 2009 08:15 PM
NuRon
Mar 7, 2008 12:11 PM
drew2
10
Nov 27, 2005 05:36 AM
lotas
Aug 20, 2004 10:21 AM
