Replacing the Radiator support
Old Feb 24, 2007 | 09:29 PM
MildWater's Avatar
Default Replacing the Radiator support
How hard is it to remove and replace a radiator support for a 97 ek? I got into an accident and i wanted to see if i can do this without having to weld or take it into a repair shop...
Old Feb 24, 2007 | 09:30 PM
turbociviccoupe's Avatar
Default Re: Replacing the Radiator support (MildWater)
you have to weld it
Old Feb 24, 2007 | 09:40 PM
dad0c402's Avatar
Default Re: Replacing the Radiator support (turbociviccoupe)
I used a drill for the spot welds, after awhile you can get the welds out and not even punch through. Then I used jb weld to hold it all together, clamped tight and let to sit over night. Checked it over and over for months after I did it and still holds perfect, just make sure the support sits properly and is clamped down right.
I was scepticle at first but I'd figure I try this first and keep checking it and If i see a single crack at least I can drive it somewhere to get a couple welds put on it for not much more.
Old Feb 24, 2007 | 09:54 PM
MildWater's Avatar
so i just drilled out the spot welds and unbolted it? then later used JB weld in place of re-spot welding it?
Old Feb 25, 2007 | 10:49 AM
MildWater's Avatar
bump
Old Feb 25, 2007 | 10:52 AM
Eran's Avatar
HT White Ops
While JB weld may work, I would not leave it as a permanent solution. Take it to a shop to get tacked back in after you have it clamped with JB-Weld.
Old Feb 25, 2007 | 08:10 PM
dad0c402's Avatar
Default Re: (Eran)
I simply sanded all the spots that the radiator support would contact to the frame, cleaned it real good, and put on as much jb weld as possible w/o getting messy or a thick layer. The beefy part of the radiator support is held on by big bolts, so that helps, the ony thing I was worried about was vibration and so far everything is still perfect.
hectic947
Dec 12, 2010 02:59 PM
Boostn B20
Aug 21, 2008 02:27 PM
GSR_96814
Welding / Fabrication
Mar 4, 2006 07:56 PM
1fastVX
19
Jun 28, 2005 02:55 PM
drunknmunkypow
Aug 10, 2003 07:40 AM
