Need some advice... take a look at some pictures...
Honda-tech,
So I picked up a car lately, and i got home to change the oil, but i noticed some peculiar things around the oil pan... the bolts/nuts that hold up this oil pan are not all uniform. some are bolts, some are nuts, and then on a couple bolts, the nuts are missing! i'm kind of lazy to check my other car - a gsr, to see if this was supposed to be the case... to have some bolts used to keep the pan up and on others, to be nuts (if that makes any sense...) here are some pictures:
Picture 1: (you'll see on the left, it's a nut... and then you'll see on the right that the nut is MISSING!)
Picture 2: (now, you'll see a bolt, MISSING nut, bolt, and bolt)
What the heck is going on??? I changed the motor oil and there doesn't seem to be any oil leaking, though... for now at least
The oil pan is held on with a combination of bolts and nuts. If the hole is completely empty, the STUD has fallen out. The reason why they are all gone is because the were not torqued down correctly.
Jo, the oilpan has threaded studs and bolts. Your leak is def. because you are missing some of the fasteners. Easy fix... we can hit it on the 10th. Get a new gasket and new bolts.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by migs »</TD></TR><TR><TD CLASS="quote">The oil pan is held on with a combination of bolts and nuts. If the hole is completely empty, the STUD has fallen out. The reason why they are all gone is because the were not torqued down correctly.</TD></TR></TABLE>
thanks!
thanks!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Comp97GSR »</TD></TR><TR><TD CLASS="quote">Yeah, a 4 door GSR
no...
i was looking for another db8... but i decided to get a 2-door. it's still sinking in and i still feel sick seeing my beat up db8. i don't think the fact i picked up a two door will sink in till i sell the db8 and my new car is sitting in my garage... ugh
</TD></TR></TABLE>no...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Comp97GSR »</TD></TR><TR><TD CLASS="quote">Jo, the oilpan has threaded studs and bolts. Your leak is def. because you are missing some of the fasteners. Easy fix... we can hit it on the 10th. Get a new gasket and new bolts.</TD></TR></TABLE>
Oh I wonder what you guys could be doing on that weekend?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bradstard »</TD></TR><TR><TD CLASS="quote">
Yep, swapping the C5 with the C1 and shipping you the C1.
I hope it is at least 50* out that day. Nothing like laying back down on a 30* garage floor for 2 hours.
</TD></TR></TABLE>Yep, swapping the C5 with the C1 and shipping you the C1.
I'll disagree with you on that Migs, I bought my car new and at 25,ooo miles some of mine had started to back out. Then I brought it in for a warranty claim many thousand miles later and the dealer saw that some were missing and some were only finger tight. There was no explanation given for this, but my reasoning is the vibrations, heat/cold got them loose. And to make sure of one point I almost forgot, I did tq them to spec at 25,ooo and they still got loose. I have just added them to the normal maintenance list of things to do at each oil change.
