HELP asap! clutch wont disengage
Old Feb 24, 2007 | 05:31 PM
hndacord02's Avatar
Default HELP asap! clutch wont disengage
I have a 99 civic si. When i push the clutch in, i have to push the pedal all the way down to the floor, and really push it against the floor to disengage it. And when i let it out, the clutch pedal doesnt come back up all the way! please help me out asap with what is goin on!! thanks...
Old Feb 24, 2007 | 05:55 PM
RCautoworks's Avatar
Default Re: HELP asap! clutch wont disengage (hndacord02)
Air in the lines, try bleeding the system. Look under the dash, make sure the peddle is not broken, usually only occurs with ef's because of the cable pressure though.
Old Feb 24, 2007 | 08:09 PM
MiX's Avatar
MiX
Default Re: HELP asap! clutch wont disengage (RCautoworks)
just replace the slave cylinder. they are pretty cheap from the parts store. Then bleed it and it should solve your problem.
Old Feb 25, 2007 | 12:45 AM
hndacord02's Avatar
Default Re: HELP asap! clutch wont disengage (MiX)
aight, this wouldnt have anything to do with needing a new clutch at all would it? what would those "symptoms" be? thanks for the help guys
Old Feb 25, 2007 | 02:14 AM
yoej8's Avatar
your clutch should be fine, symptoms of a dead clutch would be like you put it in gear and the car barely moves.
Your problem most likely lies within the hydrolic system. Look down by your clutch and make sure it doesn't have stuff leaking from it. If it doesn't just proceed to bleed the clutch lines. If the problem still persists, you might have to change out either the master or slave clutch cylinder.
Old Feb 25, 2007 | 02:30 AM
hoya_10fintec's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MiX &raquo;</TD></TR><TR><TD CLASS="quote">just replace the slave cylinder. they are pretty cheap from the parts store. Then bleed it and it should solve your problem. </TD></TR></TABLE>
my friend had the same problem... I just replaced the slave cyl.
Old Feb 27, 2007 | 05:05 PM
hndacord02's Avatar
Default Re: HELP asap! clutch wont disengage (hoya_10fintec)
ok, it was the slave and the master cylinder that went on it! i got it all fixed, and running right
Old Feb 27, 2007 | 07:17 PM
d16z6 eg6
Sep 16, 2009 02:36 PM
Streetneon2185
Sep 17, 2007 03:24 PM
KRAP DIVAD
Sep 4, 2005 05:10 PM
ls95hatch
May 24, 2003 09:34 PM
