Clutch problem...please help!
alright i'm really hoping someone will be able to help me out here, as i need my car asap.
my problem is, all of a sudden when i go to depress the clutch pedal, it has no tention in the first 3-4 inches of travel, then at the bottom i feel it finally grab. Its also engaging on take off extreamly low.
at first i thought maybe a clutch cable, but then icome to find that the civic doesnt have a clutch cable like most cars do. so then i turned to the clutch, but i didnt have any warning signs at all, just all of a sudden this morning it was like this.
please someone help me out, i dont wanna get stranded on the side of the road on my way to work.
Re: Clutch problem...please help! (Streetneon2185)
What car do you have that would help us to help you
okay anyway if you have a civic with a hydro tranny try bleeding the clutch master,
or you might have a bad master
you can adjust your pedal from under the dash to..., but it is suppost to have atleast 1 inch of play .........
Re: Clutch problem...please help! (4gencivicef9)
great thanks a lot, that was it, my fluid was severly low.
thanks so much for the peace of mind now
Modified by Streetneon2185 at 1:17 PM 9/17/2007
check for leaks on your clutch slave and clutch master cylinder. had the same issue, turned out to be a bad clutch slave which caused the clutch from not engaging. leaked out fluid. you can DIY easy.. but check all those little things first... my .02 cents...
Hybridize
04-20-2008 05:01 PM
