what do you think of these with some jun 3's
what kind of power figures are we looking at, with a 01 itr with mugen header, exhaust, carsound cat, ATS final, toda flywheel, and exedy clutch (oh yeah drop in filter)
With these pistons and jun 3's and a tuned ECU, what type of power at the wheels are we looking at
12.5:1 compression ratio, JUN/Cosworth pistons
[Modified by hooptie157, 10:49 AM 5/21/2002]
I've heard of this from a retailer of JUn prods, cool guy but he didn't want to tell me the company that makes them. He told me all I would be doing is paying for there name, but that's it no mo details. I would mind getting me a set.
[Modified by azn98R, 11:38 AM 5/21/2002]
Would I have to make any mods other then valve train mods to accomdate these pistions?? I'm really thinking of getting them
can I run pump gas with 12.5:1 compression?
[Modified by hooptie157, 9:01 AM 5/21/2002]
Holy Compression Ratio, Batman! Is 12.5:1 even streetable with shitty SoCal Petrol (91 r+m/2)?
Is there anything one can do to the head that reduces CR? Opening up comustion chambers or the like?
With those pistons, you would end up with a set-up requiering very good tuning. You should not have to modify the valve train because of the pistons but because of the more aggressive camshafts.
12.5 CR is getting border line to run pump gas IMO.
From what I have seen of the Jun camshafts, I would think you'll get around 215 WHP
I think 11.5 is as high as you should take it here in SoCal.
You should remove the link in your first post if you're really interested in them.
Someone may beat you to the punch.
I'm in NJ with 94 octane gas readly available what do you think???
12.5 is probably okay with 94 ocatane again you should probably ask someone whose done that, i dont know anyone that has that high compression so i cant answer from experiance.
hey fooo!!!!
its basically the same setup I have in my car you heard it man the switchover the idle
Im running the 12.5s but the Jun/Cosworths I think are slightly lower judgeing by the fact that the dome isnt a point like mine are
get them you wont regret it
and itll work with Jun3s
designed as a package
you will need valvesprings and retainers for the cams tho
and an ECU to make it run **** and ***
and if u get a Jun proggy you wont have the wonderful vtec flutter
that every other proggy gives at switchover
I love my setup
and it pulls mad but cant wait to dyno
I love my setup
Those pistons are low compression and VERY OVERPRICED.
