exhaust/oil smells like gas
Old Feb 24, 2007 | 04:59 PM
GsrTurboCRX88's Avatar
Default exhaust/oil smells like gas
Recently my crx with ls vtec started to run very poorly at low rpms, smokes quite a bit (sometimes white and blue) and the exhaust and oil smell like strait gas. now i have a really loud engine knock. The engine was just rebuilt last summer with new rings, rod bearings, crank bearings, head gasket, ect. I was thinking my rings are goin bad, what do you think?
Old Feb 24, 2007 | 05:48 PM
Mavrick's Avatar
Default Re: exhaust/oil smells like gas (GsrTurboCRX88)
rings are really going bad. The smoke is from oil getting into the combustion chamber from bad rings and the gas is getting past the rings and into the crankcase. Also sounds like a major mixture problem too
Old Feb 24, 2007 | 07:41 PM
Default Re: exhaust/oil smells like gas (Mavrick)
I should have checked the compression. i will tomorrow and post the results
Old Feb 25, 2007 | 02:17 PM
ok, i did two compression tests. first time:
#1 200
#2 205
#3 180
#4 205
then i tested again and got
#1 200
#2 205
#3 90
#4 200
All the plugs are black and reak of gas
why would #3 go from 180 to only 90?
Old Feb 25, 2007 | 03:48 PM
97grnrs's Avatar
are u doin the test right? throttle blocked open and about 5-7 cranks of the motor? and motor warm? and make sure gauge is tight
Old Feb 25, 2007 | 05:25 PM
Default Re: exhaust/oil smells like gas (97grnrs)
yea it was done right
Old Feb 25, 2007 | 07:22 PM
Mavrick's Avatar
something is goofy with that ring and sometimes it seal and sometimes it doens't. You need to re do the rings to get high compression
Old Feb 25, 2007 | 11:12 PM
i did a wet compression test and it was still at 90. I guess either way i am due for a rebuild. This time i am using only oem parts
TheBook
Mar 30, 2013 02:30 PM
h22accordian
Feb 28, 2011 10:42 PM
msinsky14
Dec 10, 2007 05:05 PM
egturbo
Aug 1, 2004 09:28 PM
URA91hatch
Aug 1, 2004 06:30 PM
