Blox Type B
Old Feb 24, 2007 | 03:04 PM
FastGsr95's Avatar
Default Blox Type B
Can u run the blox type b on a gsr motor with itr pistons and not have any clearance problems?
Old Feb 24, 2007 | 04:00 PM
ALLphilthyDC2's Avatar
Default Re: Blox Type B (FastGsr95)
it shouldn't be any problem
Old Feb 24, 2007 | 10:50 PM
all-mtr-teg's Avatar
Yes sir, just installed the same setup in my homies ride, just waiting to get a tune on monday. So far, he's been driving it with a chipped p28 with a custom basemap. About 800 miles on it so far.
Old Feb 25, 2007 | 05:24 PM
FastGsr95's Avatar
Well I had a shop install them and then started dyno tuning it and they said they weren't working and they were to big so then I had to order the type a's and they put those in. I was wondering if i got had. Now I have a extra set of type b's. And Would it be worth it to take the a's out and put in the b's. Im making 184 with gsr and itr pistons
Old Feb 25, 2007 | 07:52 PM
My cousing put down 192 hp i believe on his type R, and he had supertech v.s. Blox B's and bolt ons. No head work, and stock t.b. So 184 hp w/ type A's and itr pistons looks pretty good to me, assuming you got i/h/e?
Old Feb 25, 2007 | 08:19 PM
turboedc2's Avatar
Default Re: Blox Type B (all-mtr-teg)
which series are you guys talking about comp series or tunner series? i heard the comp series are better is that true...
Old Feb 25, 2007 | 08:31 PM
SiB16A's Avatar
Default Re: Blox Type B (turboedc2)
competition series is more agressive...
Old Feb 25, 2007 | 08:33 PM
Natural Aspirations's Avatar
Default Re: Blox Type B (SiB16A)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SiB16A &raquo;</TD></TR><TR><TD CLASS="quote">competition series is more agressive...</TD></TR></TABLE>
NOT TRUE, same lift and duration different lobe widths. Same cam built different, not good on used rockers.
Old Feb 25, 2007 | 08:43 PM
turboedc2's Avatar
Default Re: Blox Type B (Natural Aspirations)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Natural Aspirations &raquo;</TD></TR><TR><TD CLASS="quote">
NOT TRUE, same lift and duration different lobe widths. Same cam built different, not good on used rockers.</TD></TR></TABLE>so you think tuner series are better or wat?...
Old Feb 25, 2007 | 08:46 PM
SiB16A's Avatar
So is there a big difference between the cams performance wise?
Labeling one Tuner and the other Competition, what would explain the difference...?
just the lobe widths?
Old Feb 25, 2007 | 08:59 PM
JUST lobe widths, same performance spec's
Old Feb 25, 2007 | 10:28 PM
SiB16A's Avatar
Default Re: (Natural Aspirations)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Natural Aspirations &raquo;</TD></TR><TR><TD CLASS="quote">JUST lobe widths, same performance spec's</TD></TR></TABLE>
Thanks for the info
Old Feb 26, 2007 | 03:29 AM
FastGsr95's Avatar
Default Re: (SiB16A)
So type b would have worked but would have got around the same performance with them. And whats i/h/e?
Old Feb 26, 2007 | 07:25 AM
Default Re: (FastGsr95)
I/H/E = Intake/Header/Exaust system, common bolts ons. I think the blox type b's would have been perfect for your car with ITR pistons. They would have been too much had you had stock compression. But with JDM ITR pistons, your compression should have been great for those cams. I was gonna use the same cams in my gsr, but at the time, i didn't have my ITR pistons installed yet.
Old Feb 26, 2007 | 12:02 PM
FastGsr95's Avatar
Default Re: (all-mtr-teg)
I just can't belive the shop charged me to install the b's dyno it say they don't work and then charge me to install the type a's then dyno it again. They got me bending over pretty much
Old Feb 26, 2007 | 08:28 PM
I hope you still got the type b cams, they are good cams and sell quick
Old Feb 27, 2007 | 06:18 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FastGsr95 &raquo;</TD></TR><TR><TD CLASS="quote">I just can't belive the shop charged me to install the b's dyno it say they don't work and then charge me to install the type a's then dyno it again. They got me bending over pretty much</TD></TR></TABLE>
What was it about them that did not work?
What are your engine spec's?
Was it the shop that recommended you the Blox B cams?
Old Mar 2, 2007 | 03:40 AM
FastGsr95's Avatar
The car wouldn't stay in vtech is what they told me it would hit vtech on the dyno then he said hondata would put the car in limp mode so it wouldn't blow itself up. They said the type b's would be to big.
Old Mar 2, 2007 | 05:06 AM
Find a new shop they are lying. The ecu does not have the capability to do that.
Old Mar 2, 2007 | 09:23 AM
SiB16A's Avatar
that shop sucks
Old Mar 2, 2007 | 03:04 PM
FastGsr95's Avatar
Great now I spent about 1700 dollars on them installing them and tuning it.So it possible that I could get more then 184 with the type B's
Old Mar 2, 2007 | 03:43 PM
Mike@K-Tuned's Avatar
I hope that the shop had your permission when they did all that cam switching and tuning. With proper tuning it is very likely that Blox B's will make a bit more power. Do you know your exact comp. ratio? The B's like compression and seem work the best the more comp. you have. The B's also need an upgraded valvetrain.
Modified by LSvtecMike at 9:32 PM 3/2/2007
Old Mar 2, 2007 | 05:38 PM
FastGsr95's Avatar
Default Re: (LSvtecMike)
yeah i have itr pistons in a gsr yeah they had my permission I had to buy two sets of cams I have the upgraded valvetrain.But the deal is I didn't really have the money to buy another set of cams
poormans_typer69
27
Sep 25, 2006 06:52 PM
nos4a2si
Nov 14, 2004 04:19 PM
JoNNiE
Oct 16, 2004 08:49 AM
