Need help reading the degrees on the JG engine dynamics gears
Old Feb 24, 2007 | 02:22 PM
rk's Avatar
rk
Default Need help reading the degrees on the JG engine dynamics gears
I recently picked these up from my buddie on here and I'm just trying to figure out what markings on these cam gears represent degrees
Seeing as 0 is the taller line, would the following 2 taller lines on each side be the 1 degree marks?(#1)
...or are the degree markings the smaller thinner lines in-between the taller ones(#2)?
i know i know...n00b but I can't think that the smaller lines would be degree markings.
Also would anybody ever need more then +2 or -2 degrees to do tuning? are these gears fairly sufficient?
Old Feb 24, 2007 | 04:41 PM
1 2 NV's Avatar
Default Re: Need help reading the degrees on the JG engine dynamics gears (hybridEG93)
each hash mark represents 1 degree. the bigger lines are 5 degrees. you have 10 degrees each side for adjustment.
Old Feb 24, 2007 | 09:07 PM
mike_belben@yahoo.com's Avatar
From: not riding any bandwagons in, massachusetts, usa
each line also represents a valve and piston moving +/_ up to .030" closer or farther from occupying the same space at the same time, so tread very lightly.. one mark at a time.
(those arent degree's, theyre marks. in my experience, rarely do cam gear marks actually correlate to crank degrees as they're supposed to.)
Old Feb 25, 2007 | 05:23 PM
rk's Avatar
rk
Default Re: Need help reading the degrees on the JG engine dynamics gears (1 2 NV)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1 2 NV &raquo;</TD></TR><TR><TD CLASS="quote">each hash mark represents 1 degree. the bigger lines are 5 degrees. you have 10 degrees each side for adjustment.</TD></TR></TABLE>
thanks guys
this helped explain it.
dam they made the timing marks so small, its gonna be impossible to use these when tunning cam gears lol
Old Feb 25, 2007 | 05:29 PM
dont forget 1 cam degree = 2 crank degrees.
Old Feb 26, 2007 | 07:33 AM
rk's Avatar
rk
Default Re: (mike_belben@yahoo.com)
thanks mike_b
i remember reading that in a thread a few weeks back
killacam661
Aug 31, 2007 11:30 AM
skata89
Nov 26, 2006 05:00 AM
StinkyPinky
Aug 27, 2006 03:48 PM
turbotime
May 14, 2006 04:06 PM
machine4321
Mar 29, 2005 03:44 PM
