Which Koni Rear will work in my Civic?
Old Feb 24, 2007 | 01:06 PM
tilhasbb's Avatar
Default Which Koni Rear will work in my Civic?
Hello,
I have 1999 Civic SI (Canadian) (American Requivalent of Civic EX)
I am looking at the only retailers here that sell koni shocks and they tell me I need
KONI 8041-1152 Sport Sport Shock - Front
KONI 8041-1213 Sport Sport Shock - Rear
But they can't get 1213, there on backorder for months... So I am wondering will the 1153 work?
Old Feb 24, 2007 | 01:18 PM
na+b18c_hatch's Avatar
i would suggest buying the ones you need from someone who has them in stock
Old Feb 24, 2007 | 01:31 PM
tilhasbb's Avatar
According to sales rep they should be the same.
Just to be sure my car is an EK right?
Old Feb 24, 2007 | 01:41 PM
usdm 99-00 si's are known as em1's. not sure about canada. but 96-00 civics are usually known as ek chassis, yes.
Old Feb 24, 2007 | 01:45 PM
tilhasbb's Avatar
I even checked with a place in Toronto and they told me the 1213 is very hard to get. I'd rather not get used shocks.
Any idea what the difference is between the 1213 and 1153
Old Feb 24, 2007 | 04:32 PM
tilhasbb's Avatar
Default Re: Which Koni Rear will work in my Civic? (tilhasbb)
I bought these H&R Springs from my friends Integra.
Will this work with the Konis on my car?
H&R 50145
http://www.modacar.com/product....html
I am worried about the rust. is it okay can i just sand it off and repaint or leave it as is or contact H&R for warranty replacement?
(Even my stock arent rusted like that...)
Modified by tilhasbb at 5:56 PM 2/24/2007
Old Feb 25, 2007 | 12:36 PM
tilhasbb's Avatar
bump...anyone?
Old Feb 25, 2007 | 01:01 PM
Evs-One's Avatar
Solbros Owns Me
Default Re: (tilhasbb)
94-01 Integra or 92-95 Civic rears are the same, except the fork that slides over the rear lower control arm will have gaps in the side. Use about a 5 mm spacer on each side to keep the shock from moving around. I have run 96-00 rear shcks on many integras/civics, but you have to grind down the lower control arm bushing to get the shock to fit.
Old Feb 25, 2007 | 02:45 PM
tilhasbb's Avatar
Evs-One> Thanks
What about the springs?
Old Feb 25, 2007 | 03:23 PM
Evs-One's Avatar
Solbros Owns Me
yup, Integra coils will work also...spring rates I believe are only slightly higher than those of the Civics...may need to check that out, but they will fit fine
Old Feb 25, 2007 | 05:58 PM
tilhasbb's Avatar
thanks for the prompt reply.
What about the rust?
Should i get a dremel sand it off and repaint it?
not sure what paint to put because it will have to stretch back and forth.
Jaminak
Oct 14, 2011 12:35 PM
edoyboy
Suspension & Brakes
13
Jan 14, 2005 05:31 AM
lilbucu
10
Nov 9, 2004 05:30 PM
FBP Ex-T
Feb 19, 2002 05:34 PM
coop94ls
Jul 31, 2001 09:56 PM
