Crome 1.2 Technical Question
Old Feb 24, 2007 | 12:55 PM
95IntegraRS's Avatar
Default Crome 1.2 Technical Question
Last night we began doing some tuning on a friend on mines LS/VTEC T04E 50 trim setup. This is not the first Crome tune I have done, so I figured it would be simple enough.
Well, we get to the WOT tuning and we run into a problem, and this is where the question lies.
When I go wide open from 3000 up, the map goes fat (below 10:1) from 3000 until the VTEC crossover. Once the VTEC crossover occurs, the map is nailed with a consistent 12:1 AFR.
What I am wondering is has anyone ever encountered this before? I have tried changing low cam/high cam fuel tables under the specified loads without change to the AFR. I have also tried messing with the multiplier tables without change.
Any help is appreciated. Thanks!
Old Feb 24, 2007 | 01:52 PM
98vtec's Avatar
moderator emeritus
Default Re: Crome 1.2 Technical Question (95IntegraRS)
are you using pro to datalog a/f or are you using a separate datalogger?
Old Feb 25, 2007 | 12:03 PM
We are using a tailpipe sniffer to see the A/F ratio
81.5mm ej8
Engine Management and Tuning
10
Nov 22, 2016 05:17 PM
dj211855
13
Dec 27, 2011 06:48 PM
boogienights
Oct 9, 2010 05:58 AM
Coutts
Jul 16, 2010 12:36 AM
Jim Truett
Dec 3, 2006 05:17 AM
