98 Accord sedan brake lights out __not bulbs, not switch?? where is brake fuse?
Old Feb 24, 2007 | 12:43 PM
maddscientist305's Avatar
Default 98 Accord sedan brake lights out __not bulbs, not switch??
I don't know what the heck is going on? All three lights are out (two and the one in the rear window). I checked the switch the three bulbs and all the fuses in the three fuse compartments (driver side and pass side dash and engine compartment). The brake light in the gauge cluster is on too.*EDIT-that was the e-brake light in the cluster* What else is there to check?
Modified by maddscientist305 at 11:43 PM 2/24/2007
Old Feb 24, 2007 | 01:47 PM
hondadude's Avatar
Default Re: 98 Accord sedan brake lights out __not bulbs, not switch?? where is brake fuse? (maddscientist30
You checked under hood fuse box, fuse #47 20 amp?
you have a test light or meter?
I have the schematics in PDF file if you want to message me your email address
Old Feb 24, 2007 | 02:56 PM
Yup I checked all the fuses and they're fine! Didn't check any relays (do i need to?). I do have a multimeter. The switch is open with the pedal unpressed and closed (has continuity) with the pedal depressed. That eliminates the switch as the culprit right? Grounds are good at each bulb harness but no power to the brake lite wires. I have 12V at the switch harness, good ground on one wire, and somewhat of a ground on the other wire (was like 1.$%@ kOHMS when continuity is usually 0.000 kOHMs).
NOTE: My trunk light was always intermittently working, and dome light does not work on the "ON when doors open" mode, only the always on mode or off. May be part of the problem. ENDNOTE
Could you send me the schematic please? It may help me. Thanks for the help!!
Old Feb 24, 2007 | 03:02 PM
Old Feb 28, 2007 | 02:12 PM
Problem solved...loose harness in fuse panel not plugged all the way in. Thnx!
Old Mar 3, 2007 | 08:05 AM
voodoo on 23s's Avatar
can u tell me which harness it might be cuz im having the same problem
DerekHollister
Apr 4, 2016 02:06 AM
99civic4dr
May 25, 2012 02:04 PM
Type-Spaz
Oct 2, 2011 04:44 PM
Storm13
Sep 14, 2010 07:07 PM
ATLHONDA
Mar 22, 2010 04:34 AM
