ECU question!!!
Old Feb 24, 2007 | 12:15 PM
DA_JDM's Avatar
Default ECU question!!!
If i have a red light comming from the little window on the side of my ecu...is that meen that my ecu is not working properly???
Old Feb 24, 2007 | 12:55 PM
Fezzie's Avatar
Default Re: ECU question!!! (DA_JDM)
its working alright... count the number of time the light flashes and that number if your code thats its throwing.....theres something wrong with your car
Old Feb 24, 2007 | 01:19 PM
DA_JDM's Avatar
Default Re: ECU question!!! (Fezzie)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Fezzie &raquo;</TD></TR><TR><TD CLASS="quote">its working alright... count the number of time the light flashes and that number if your code thats its throwing.....theres something wrong with your car</TD></TR></TABLE>
Im sure it doesnt work properly...i have since 8 months now a fuel cut off at 3500rpm often...ive never notice the light comming from the ecu
Old Feb 24, 2007 | 01:20 PM
DA_JDM's Avatar
And its a P28 w/ hondata s100...in a obd0 car with a obd0 to obd1 wiring convertion kit!!! No check engine light comming from the car...and ive change dizzy 3 time and it still wont stop!!!
Check the link for detail: https://honda-tech.com/zerothread?id=1894804
Modified by DA_JDM at 2:44 PM 2/24/2007
Old Feb 24, 2007 | 03:00 PM
Fezzie's Avatar
damn sry you got me there i dunt know much about fuel cut and **** sry
Old Feb 24, 2007 | 03:03 PM
DA_JDM's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Fezzie &raquo;</TD></TR><TR><TD CLASS="quote">damn sry you got me there i dunt know much about fuel cut and **** sry </TD></TR></TABLE>
Its ok thanks anyway bro Need help guys just tell me how to find out if my ecu is bad or not??? I will try a stock obd1 P30 in an hour from now
Old Feb 24, 2007 | 10:13 PM
Darth_Accord90's Avatar
Does it act like it wants to stall, or like it's starving for air/ fuel @ 3500rpms? Damn, my car's doing the same thing!!!
Old Feb 25, 2007 | 09:05 AM
DA_JDM's Avatar
Default Re: (Az_Honda)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Az_Honda &raquo;</TD></TR><TR><TD CLASS="quote">Does it act like it wants to stall, or like it's starving for air/ fuel @ 3500rpms? Damn, my car's doing the same thing!!!</TD></TR></TABLE>
Its like a fuel cut at 3500rpm...Its producing back fire from the exhaust in the same time that its fuel cut and the car has no power at all...
Old Feb 27, 2007 | 06:07 PM
Default Re: (DA_JDM)
Fezzie has a point. Count the # of blinks ur ECU is throwing. ei. 1 long blink and 3 short blinks means 13, then you would look in a manual at ECU codes, and compare that with the code in ur book. I just found out that my dizzy is my problem. It threw 4 blinks, and I compared it to my manual and found my prob.
Old Feb 28, 2007 | 08:59 AM
DA_JDM's Avatar
Default Re: (Darth_Accord90)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Darth_Accord90 &raquo;</TD></TR><TR><TD CLASS="quote">Fezzie has a point. Count the # of blinks ur ECU is throwing. ei. 1 long blink and 3 short blinks means 13, then you would look in a manual at ECU codes, and compare that with the code in ur book. I just found out that my dizzy is my problem. It threw 4 blinks, and I compared it to my manual and found my prob.</TD></TR></TABLE>
I have a 91 integra converted to obd1...the ecu dont throw cell its on my cluster...when i turn the key on the light comes out and stay there...no blink...and i have no cell in my cluster!!!
NAEGH22
Engine Management and Tuning
Sep 12, 2010 09:14 PM
sublimenerd
Oct 19, 2006 09:11 PM
Chris_Bye
Jul 10, 2004 12:10 PM
Defiant1999
Jun 3, 2003 10:41 AM
