Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
Breaking Axles?
Old Feb 24, 2007 | 12:07 PM
Demonis's Avatar
Default Breaking Axles?
My friend always tells me his stories of snapping axles at the track with his EM1. Is this possible with stock power, or slightly modded power such as my car?
Old Feb 24, 2007 | 12:19 PM
Ding's Avatar
Default Re: Breaking Axles? (Demonis)
I think only time will tell. Right now the car is so new. I would hope that the axles would be able to support some extra power.
Old Feb 24, 2007 | 02:26 PM
COMplex.'s Avatar
http://www.driveshaftshop.com/item170740.ctlg
http://www.driveshaftshop.com/Civic2006.ivnu
Old Feb 24, 2007 | 03:39 PM
9bells's Avatar
OG Fabricator
Default Re: (.COMplex)
I'm sure they are the same basic deal as the rsx, and I did 125 passes on my stock axles on sticky street tires, with best of 2.0 60 fts with no problems. Even the clutch was still good. Differential destroyed the whole tranny 2 passes after my 13.7 run, but axles and clutch were good.
I was about 40whp better than stock.
Old Feb 24, 2007 | 05:31 PM
Demonis's Avatar
wow a new tranny, something else id like to not break
Old Feb 24, 2007 | 06:51 PM
RICO_'s Avatar
NO MERCY!
Default Re: (9bells)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 9bells &raquo;</TD></TR><TR><TD CLASS="quote">I'm sure they are the same basic deal as the rsx, and I did 125 passes on my stock axles on sticky street tires, with best of 2.0 60 fts with no problems. Even the clutch was still good. Differential destroyed the whole tranny 2 passes after my 13.7 run, but axles and clutch were good.
I was about 40whp better than stock.</TD></TR></TABLE>
Wow. That's not too good. Well I guess 125 passes it quite alot for a tranny anyway.
Old Feb 24, 2007 | 08:17 PM
HondaF1Fanatic's Avatar
One way to tell if you are over stressing your stock axles is to draw 2 short lines, exactly in line with each other, at both ends of the axle. After you go to the strip, look at the lines, and if they don't line up anymore, you have twisted the axle. Over time this will cause failure. I find it very unlikely on a moderately modified 2wd car with street tires that this will occur. You may have to worry if you are pushing much more power or using slicks, but that is just common sense.
Jon
Old Feb 25, 2007 | 05:35 AM
9bells's Avatar
OG Fabricator
Default Re: (RICO_)
The stock diff is crap.
Look at all of the open area. All the teeth are gone on the bottom, and most on the spider gears. The quaife next to it is billet, and visibly beefier.
It sucked, and was expensive, but you gotta pay to play.
8Gomer9
Mar 29, 2007 08:34 AM
EG type GTR
Jul 5, 2006 01:32 PM
92gsrteg
May 10, 2006 03:40 PM
376R
Apr 18, 2005 09:30 PM
HybridMT
Nov 1, 2001 09:05 AM
