FS: Y7 block w/ Y8 head
Y7 block w/Y8 head, ARP head studs, OEM head gasket.
$500, unless I have to ship it. Would prefer local pickup from San Jose, CA area.
It can come with:
Red valve cover, powdercoated & chipping OR stock valve cover.
With y7 stock oil pan OR with Y8 tapped oil pan and oil feed lines for turbo.
I also have a y7 head to match the block, I will throw that in if you want it.
IT NEEDS a distributor cap, I broke a plug with the engine lift chains.
This setup had about 6K on it before the car was totalled. It ran after the wreck, started right up.
It can come with:
vegaskurt
Aug 20, 2005 03:49 PM
