will these rims fit....
looked through the threads and couldn't find what i was looking for...
will this size rim fit.... 18x8.5 +37 offset???
what different rim setups are you guys running....
i'll roller is currenly running 17x8 (35) i believe with 215 45 17's and has some rubbing issues
nothing major...
alot of clubrsx guys push the 8.5 width which is where i'm assuming this question is coming from if you see rims for sale...
with the right tire combo...and possible rolling of fenders it could "probably work"
nothing major...
yeah i would think 215 40's but with the width and offset i don't know if it would fit the civics.... i know that would work for the RSX's....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dRo15 »</TD></TR><TR><TD CLASS="quote">yeah i would think 215 40's but with the width and offset i don't know if it would fit the civics.... i know that would work for the RSX's....</TD></TR></TABLE>
WHOA BUDDY!!!!! slow the horse... time out.. white flag
215/40 on 18x8.5 aint gonna work/look right.. can be done, but wouldn't be smart
you'd want something more along the lines of 225/40 or 235/40or35 (not sure about 18s really) but all i know is 215 is not wide enough for an 8.5" rim.. tires will be stretched and it will look dumb
what is the widest wheel you can go and what offset would you need to be at?
i had a del sol before my fg2 and it was slammed...i went from 195 to 205 size tires and had rubbing issues on 6.5 wheels with 35 offset
an 8.5 +37 should fit perfect, and you should be able to fit a 225 without rubbing unless you're really low. If you're pretty low you'll have to stretch a 215 (which will work without any problems) or roll your fenders.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 20strong »</TD></TR><TR><TD CLASS="quote">How do you roll your fenders?</TD></TR></TABLE>
With a fender roller.
http://www.rollyourfender.com/
Duh.
Duh.
boostedEBP
Jan 9, 2008 03:27 PM
classciv
Mar 19, 2004 08:32 AM
