CTR piston, safe in b18c??
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by No_Fear »</TD></TR><TR><TD CLASS="quote">B18C GSR Head ~11.8comp
B18C Type-R or B16 Head ~11.6comp
More like 13:1.
More like 13:1.
From: ...and then along comes the fcuking policia, PA
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D-Rob »</TD></TR><TR><TD CLASS="quote">
More like 13:1.
like Derek said, much too high. Go with a jdm itr piston instead
More like 13:1.
</TD></TR></TABLE>like Derek said, much too high. Go with a jdm itr piston instead
Here's the actual calculations:
PR3 head/B18C Block
STD = 12.58636786521145
.25 OS = 12.649248792586258
P72 head/B18C Block
STD = 12.924594026551906
.25 OS = 12.989047869209281
PR3 head/B18C Block
P72 head/B18C Block
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rjgerolaga »</TD></TR><TR><TD CLASS="quote">
WOW. i wonder how long my itr would last with stock ecu on 91 octane.
You could switch the car over to E85 (85% ethanol is 106 octane) and run that compression no problem. The good news is that E85 is usually cheaper than 87octane gasoline and it makes more power than race gas. You just need 25% bigger injectors, and a dyno tune. You also loose 25% gas mileage...
car is strong and run ok with 91 but feels like its holding back a little. but with 100 it really shine and my gas mileage still the same when it was stock. also running in stock ecu.
c-townekhatch
Dec 11, 2006 05:46 PM
b16a2civicesi
21
Nov 8, 2006 09:49 AM
