Quick question for fellow 4th gen owners
Is the cruise control control back lighting the same blue as the sunroof and light adjustment? The reason why I am asking is because I think my Honda parts department is filled with idiots and they keep getting me the wrong bulb. The color that shines through is kind of white and it definitely not the same blue/green as all of the other buttons. Am I right or is it supposed to be like that? TIA.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rch022 »</TD></TR><TR><TD CLASS="quote">uhm my cruise light shines green, does it really matter?</TD></TR></TABLE>
It shines green or blue/green like all the other switches? Does it really matter? Not really, but I would like to know. I would also like to know if need to go to another Honda dealership for parts due to their incompetence.
The light is supposed to be green like everything else. When you order the bulb from honda it comes clear. You are supposed to take the rubber bulb cover off the old bulb and put it on the new one. However when I tried this the cover fell apart. The dealer could not find any part number for the cover. I would suggest trying a junkyard or find someone parting out a 4th gen. Maybe if you buy the whole switch assembly it comes with the bulbs??
http://www.hondaautomotivepart...WITCH
What we need is called a bulb gel... and yes it is that rubber thing.
My roof switch is green instead of blue/green... I think I'm gonna go in and do all the bulbs at once. I've got the 95 gauge cluster and it takes a while to warm up, I'm guessing the bulbs behind it need replacing but I can't seem to figure out which part it is on the diagram:
http://www.hondaautomotivepart...82%29
Modified by PB BB1 at 11:22 AM 2/24/2007
unclejemima
Sep 11, 2016 07:22 AM
