lowest offset that a 94-97 accord can run?
can someone please tell me whats the lowest offset a CD accord can run? im planning on a project soon and need to know this. pictures would help too. tia.
lol accords can take anything it how much work do you want to make it fit...i think the lowest i saw was a vip accord in japan +10
i plan on cutting and rolling. no pulling.
i wonder if accords can take a 10 inch rear without widen fenders... anyone can confirm this? theres a guy on here running a 9 inch with +20.
yeah the wagon dood...well his sticks out tho...but newayz you can run 9in wide with out pulling the fenders just rolling lemme ask this other guy that running 9 in the rear
edit his specs
Front - 18x8 +20 offset
Rear - 18x9 + 32 offset ( 5mm spacer to make it 27)
edit his specs
im not tryin to do any "body" mods. i really want to run a 10" in the rear badly cuz i found the set of rims i want for the accord.
will fit just if you want to slam it its going to rub and you defintly going to ahve to go Super negative camber to make it sorta flush or else its going to stick out like crazy
of course camber is a must. im just wondering if itll hit like the wheel well or sumthin if i try to mount it.
the specs of the rims im looking at are 18x10 +35
im prolly going to run a 10mm spacer or something to be on the safe side.
10" for the rears, 9" for the fronts. im more than sure the fronts will work. thats why im not asking much about the fronts.
