1999 Accord randomly cuts out
Old Feb 23, 2007 | 04:48 PM
InvaderTrax's Avatar
Default 1999 Accord randomly cuts out
It's a '99 F23A1 5 speed. Sometimes after you start it, it will cut off, and other times while driving. When it does, it'll turn over fine, but won't start. You can repete it all you want but it won't start. If you let it sit about 10 minutes it'll start right up. It used to do it rarely, but lately it's been doing it a lot more. Ignition switch vs main relay vs ? There's no open recalls, but ignition switch is always a possibility
Old Feb 23, 2007 | 04:51 PM
Loco-B's Avatar
Default Re: 1999 Accord randomly cuts out (InvaderTrax)
any overheating?? maybe a temp switch?
Old Feb 23, 2007 | 07:28 PM
Nope. Sometimes it would do it right after I start the car up. It would run for maybe 4 seconds then shut off
Old Feb 23, 2007 | 07:35 PM
blueeg's Avatar
there is a safety recall on that model accord. call the dealership and have them look up your vin to see if the switch has been replaced already. it not then go down to the dealership. the ignition switch and installation is free since its a safety recall.
Old Feb 23, 2007 | 11:44 PM
SuShiBoiiii's Avatar
Default Re: 1999 Accord randomly cuts out (blueeg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blueeg &raquo;</TD></TR><TR><TD CLASS="quote">there is a safety recall on that model accord. call the dealership and have them look up your vin to see if the switch has been replaced already. it not then go down to the dealership. the ignition switch and installation is free since its a safety recall. </TD></TR></TABLE>
yeah do that...they can do it for free...also if thats not the case 2 of my friends had the same problems on different cars and it came to be the fuel regulator....but call the dealership
Old Mar 1, 2007 | 09:09 AM
Brought it in to Honda, no open recalls. Decided to run a diag on it and see if they can find out what's wrong and so far they can't recreate it. Now, the service manager told me that during the life of these model cars, the main relay and ignition switch are more than likely to fail. I'm probably going to have the ignition switch done while it's there just because it's only $60 part and $75 labor, but I can do the relay myself (or at least inpsect it)
Old Mar 1, 2007 | 09:39 AM
AFAccord's Avatar
Default Re: (InvaderTrax)
I had the same problem, but I can't freakin remember what fixed it. Seemed like it would run fine, then I'd stop to get gas, and then it would start then immediately cut off, or just not start at all for 5-10 minutes... I'll let u know if I think of the fix.
Blaze45
Nov 29, 2017 12:07 PM
jim321
Jul 8, 2013 06:50 AM
engtaz
Jun 10, 2011 01:39 PM
JONESER
Aug 21, 2008 07:44 PM
notoriousB
Jan 11, 2005 03:28 PM
