Leak in trunk...check almost everywhere...out of ideas?
Old Feb 23, 2007 | 03:09 PM
dew_fever's Avatar
Default Leak in trunk...check almost everywhere...out of ideas?
As stated above, there's a leak in my trunk....the car was hit in the rear quarter panel(fender bender) and repaired. I've added sealer all around the car's rear from and it still leaks. Is there anything else I should check, cause I am out of ideas.
Thanks
Old Feb 23, 2007 | 03:10 PM
si937's Avatar
tail light seals?
Old Feb 23, 2007 | 03:11 PM
dew_fever's Avatar
Default Re: (si937)
BTW its a 00 lx, but yeah I haven't check those yet.
Old Feb 23, 2007 | 03:37 PM
choppedndropped's Avatar
Default Re: (si937)
close your trunk and spray it with a hose all over, then you should be able to see where its coming in.
Old Mar 1, 2007 | 03:25 AM
dew_fever's Avatar
Default Re: (choppedndropped)
I've tried that and the water seems to seep through the side near quarter panel next to the wheel. Any thoughts?
Old Mar 1, 2007 | 04:01 AM
Smoak's Avatar
Default Re: (dew_fever)
I have a 99 SI and there is a hose right behind the drivers side quater that is probably your problem. go look behind the trunk liner and see if you see a clear tube like 1/2". if not i can go look and tell you where it goes
thewrai6th
Feb 17, 2017 09:50 AM
ReVeNgEd-SoN
Aug 25, 2011 05:58 PM
mikecp
15
Aug 22, 2010 07:56 AM
cyco
Aug 9, 2003 10:41 AM
Stellar1
Feb 25, 2003 08:28 AM
