Upper control arm bushing torque specs?
Old Feb 23, 2007 | 02:55 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Upper control arm bushing torque specs?
I just replaced my upper control arms with OEM replacement arms, came with new bushings and ball joint and everything. The bolts going through the bushings seemed a little loose (not real bad) and I was just wondering if I should tighten them at all? Unfortunately it's pretty hard to get my torque wrench up in there, even with the shock removed. Helms does not list a torque spec for these bolts (not the bushing bolts that stick up through the shock tower, but the bolts that attach the actual arm to the bushings). Thanks for any help.
Old Feb 26, 2007 | 05:30 AM
Community Builder
Anybody?
Old Feb 26, 2007 | 10:37 AM
IN VTEC's Avatar
Default Re: Upper control arm bushing torque specs? (PatrickGSR94)
I'd guess around 16lb*ft for a M8 bolt or 36lb*ft for a M10 bolt. I removed the bushing brackets and installed them to the UCA's first.
That_Delsol_Guy
Dec 30, 2015 05:55 AM
meb58
Feb 7, 2008 06:26 PM
DeDonDeRosa
Suspension & Brakes
20
Mar 22, 2007 08:48 PM
DIP_SET FoReVr
Sep 28, 2004 09:35 AM
wreckedmyteg
Aug 11, 2004 06:02 PM
