OMG, another mini-me question (cam gear question)
Old Feb 23, 2007 | 02:53 PM
slowslow's Avatar
Default OMG, another mini-me question (cam gear question)
So I've seen on several sites that to get proper timing (on a b1-z6), I need to get a y8 cam gear for my z6 head... Is this true? I will also be going turbo when i swap this in.
Thanks in advance
BTW, I've searched several times. I just want a confirmed answer.
Old Feb 23, 2007 | 04:32 PM
slowslow's Avatar
Default Re: OMG, another mini-me question (slowslow)
Old Feb 23, 2007 | 05:19 PM
PACT man's Avatar
Would like to know the answer also since I'm doing the same thing.
1991hb's Avatar
I am not sure about the Y8 cam gear but you do need to get an adjustable cam gear.
Old Feb 23, 2007 | 07:42 PM
slowslow's Avatar
need quick answers! :D
Old Feb 23, 2007 | 08:34 PM
dannyk20's Avatar
all cam gear r da same size, but da timing mark r diffirent. i used da timing belt off 96 and newer civic
Old Feb 23, 2007 | 08:37 PM
jbmonster90civic237's Avatar
Default Re: (slowslow)
I used the Y8 cam gear. But if anything I would go with a adjustable cam gear. Your going turbo, and I would say your going to get it tuned, Right? If you do everything that your saying. I would do things right way. Takes some weight off your mind knowing you did things right.
Old Feb 24, 2007 | 01:06 PM
slowslow's Avatar
exactly.. thanks!!
austen95
Mar 12, 2018 06:55 PM
portenio78
Apr 23, 2006 06:26 PM
90LSpimpin
Jan 31, 2005 01:34 PM
