Digital Instrument Cluster
Hey guys, this is my first post...
Anywho, I was wondering is there a way to change my 1998 Honda Accord instrument cluster into a digital cluster (like the S2000 has)? Is there anyone that deals in these kinda things or can I straight swap the clusters from an S2000 to my Accord? Thanks.
The write up is in the hybrid section to get the convertion for the speed sensor. You will also have to re-pin the wiring harness. If you get the s2k gauge cluster make sure it comes with the pig tails for the harness.
despite the wiring...will the fit be perfect? that's the main problem for me..i'm sure i can find a way to wire it...just need the fit to be right...i'm a total n00b to bondo, molding, fitting, etc...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sam88 »</TD></TR><TR><TD CLASS="quote">Get a GPS which can show your speed. I have the MIO 310X. The speed is very accurate and it will warn you if you are speeding sometimes.</TD></TR></TABLE>
...uhh ok?
...uhh ok?
