Ignition Output Signal problem
also i had it running and it was running fine till the ecu fuse blew. after that it hasent ran sence. some one please help me ...just in case this matters i converted ove from dpfi to mpfi about 4 mounts ago.and i did the mini me swap
im having the smae problem with my i swap my crx si to another ls motor and im getting no fuel and it cranks but no start... well hope u fint wats rong with ur ride man
i am no expert but i have experienced this code(ignition input signal). i tried changing the distibitor, nothing. eventualy I found a green wire that was dicconcted, the previous owner says it was a vtech wire, but its a non vtec motor. I think it was the ignition input signal wire maybe.
that was my experience, im sure it could be something else too.
double check your wiring before buying any parts, or if you have a spare ignigtor or distributor try them out.
good luck
good luck
civic89si666
11
May 31, 2009 11:55 AM
