i finnaly got a motor for my hatchy
Old Feb 23, 2007 | 07:58 AM
bigluelok's Avatar
Default i finnaly got a motor for my hatchy
and i need help my hatch is an auto and i wanted to know if i put a sohcvtec in it is there any way to hook up the vtec with out swappng the ecu
Old Feb 23, 2007 | 08:06 AM
90IntegraGS1.8L's Avatar
you would have to get an external Vtec controler like a VAFC
Old Feb 23, 2007 | 08:16 AM
SIred91's Avatar
Rainman
Default Re: (90IntegraGS1.8L)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90IntegraGS1.8L &raquo;</TD></TR><TR><TD CLASS="quote">you would have to get an external Vtec controler like a VAFC</TD></TR></TABLE>
And those suck *****.....Do it right the first time.
If you can't afford it right now, then save money.
Don't half *** **** like every little teenager these days with
the "want what I want and want it now" attitude.
Do it right, you will thank me.
Old Feb 23, 2007 | 08:42 AM
bigluelok's Avatar
Default Re: (SIred91)
i understand doing it right the first time but my car doesnt run as it is and i need a car to get around in the mean time and i dont need the vtec so do u think it would work with out hooking up the vtec. and if u had to choose a vtec controller which one would u choose?
Old Feb 23, 2007 | 09:03 AM
whiteknightef's Avatar
Default Re: (bigluelok)
a vtec controller , for a good one is about the same price as doing a obd1 conversion from rywire.com. dont get a vtec controller i had one and i hated it! it is only good for tweaking (in my opinion) after you have vtec working with the correct ecu!
Old Feb 23, 2007 | 09:09 AM
bigluelok's Avatar
Default Re: (whiteknightef)
the problem im having is that my car is an automatic and i dont have the time or money to do the auto----&gt;manual swap and its hard as hell to find a good auto ecu that has vtec
Old Feb 23, 2007 | 09:17 AM
bigluelok's Avatar
if i end up getting an ecu which one should i get
Old Feb 23, 2007 | 09:29 AM
danmdevries's Avatar
An auto p28 with an obd0-obd1 conversion harness from rywire.
Are you already MPFI? if you are, you can just use all your current hardware, you just won't have vtec.
Old Feb 23, 2007 | 09:31 AM
bigluelok's Avatar
Default Re: (danmdevries)
no not yet im going to do that when i swap the motor
Old Feb 23, 2007 | 06:19 PM
joethejoeman's Avatar
if u must get a contorller get a apexi vafc II , make sure it is compatable w\ ur wiring
Old Feb 23, 2007 | 06:20 PM
dr_latino999's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by danmdevries &raquo;</TD></TR><TR><TD CLASS="quote">An auto p28 with an obd0-obd1 conversion harness from rywire.</TD></TR></TABLE> Ding ding, we have a winner!
Old Feb 23, 2007 | 07:01 PM
Crx Jimmy's Avatar
Default Re: i finnaly got a motor for my hatchy (bigluelok)
I think you can use your stock ecu and chip it with turboedit and use the ac output to turn the vtec on.
Geezer97
Jun 23, 2005 03:16 AM
H22A_HB
Oct 25, 2004 12:57 PM
cookci
Apr 6, 2004 01:24 AM
jammin civic
11
Oct 9, 2003 10:59 AM
South Bay Surfer
11
Apr 24, 2003 10:34 AM
