Eagle Rods
Old Feb 23, 2007 | 06:45 AM
kornerk12's Avatar
Default Eagle Rods
I just picked up a set of forged eagle h beams for my mild build. Anyway the rods are not numbered or say which way faces wut ? Obviously you keep the rod cap on the same way it came but does it face the side of the block facing the front of the car or the rear ? Theres numbers and letters on rod sides of the caps.
Also the rods dont look like they have any type of hole for oiling which is wierd the only thing on the inside of them is the little place for the bearings to snap in.
Old Feb 23, 2007 | 06:46 AM
b19coupe's Avatar
Default Re: Eagle Rods (kornerk12)
The bearing notches go towards the front or exhaust side of the motor.
Old Feb 23, 2007 | 06:50 AM
kornerk12's Avatar
Default Re: Eagle Rods (b19coupe)
Ok good.
Does it matter which rod i use for each cylinder ? Because i know on some chevy motors ive done they were numbered on the cap.
Old Feb 23, 2007 | 06:53 AM
b19coupe's Avatar
No. You just need to have your bearing clearances measured on each rod and select the appropriate bearing accordingly.
Old Feb 23, 2007 | 06:55 AM
kornerk12's Avatar
Ok. And lastly do most honda rods have an oiling oil around where the bearing would sit....i see the holes up by the pin but dont see anything by the cap.
Old Feb 23, 2007 | 07:06 AM
b19coupe's Avatar
The oil goes from the crankshaft to the rod bearing.
Old Feb 23, 2007 | 09:42 PM
kornerk12's Avatar
In the honda manual for stock rods it says to have the numbering on the rod itself facing the front (timing belt side) of the motor. But with these the numbering cast into it face the flywheel side if u have the notches facing towards the front of the block. Idk if its just eagle using a different way than honda or what.
Old Feb 24, 2007 | 04:16 AM
Jay_Sensing's Avatar
The numbering doesn't matter on an aftermarket rod man, just face the notches fwd like B19 coupe stated and you will be fine.
The manual was written with the installation of Honda OEM parts in mind
Old Mar 4, 2007 | 08:59 PM
kornerk12's Avatar
Default Re: (Jay_Sensing)
ok....so you just make sure the notches face the front (front of the car after the block is installed) and which cylinder each goes in doesnt matter . Correct ?
Old Mar 5, 2007 | 05:35 AM
lohatch's Avatar
Default Re: (kornerk12)
no it doesnt matter which hole you put the rod in. just have the bearing tangs on the ex side
Old Mar 5, 2007 | 06:35 AM
CaseBone's Avatar
I think you're getting in over your head!
Old Mar 5, 2007 | 08:03 AM
kornerk12's Avatar
Default Re: (92B18C1Teg)
no ive rebuilt a few chevys but the rods on those are numbered which is why this kinda confused me. They were stock though.
Old Jul 21, 2007 | 08:37 PM
yaoming315's Avatar
when you guys say bearing notches, or the bearing tangs face the exhaust side, I'm looking at my helms now. Do you mean the little hole on the top bearing (piston side) that has a hole face the exhaust side? According to helms, it says it faces the oil filter side. can someone clarify this for me.
iownahatchback
Jan 31, 2010 05:54 PM
the.hamburglar
Feb 18, 2007 10:43 AM
minivan81
Apr 5, 2004 04:38 AM
