Horn not working
Old Feb 23, 2007 | 06:11 AM
EJ ITO's Avatar
Default Horn not working
I've checked the fuses and check if the horn was connected, but nothing I hit the horn button and nothing goes off, any suggestions?
Old Feb 23, 2007 | 07:12 AM
JDMFantasy2k's Avatar
Default Re: Horn not working (EJ ITO)
make sure the area where the horn connects to the car is good. The horn gets its ground from being connected directly to the chassis and i had a bad connection once. So take your bumper off, unbolt the horn and scuff both surfaces with some sandpaper and make sure the power connection is good. Also while you got the front bumper off, stick a test light or multi meter in the positive wire and have someone hit the button, see if you got power. Maybe your horn took a ****.
Old Feb 23, 2007 | 07:39 AM
excivicboy96's Avatar
Default Re: Horn not working (JDMFantasy2k)
if he has a 96-00 civic he'd just have to remove the grill. unless he has large hands. My horn buttons on my wheel never worked since i got my car. but a new switch was wired in. i've been working at diagnosing the switch not working and have come to it being the relay.
Old Feb 24, 2007 | 05:59 AM
Default Re: Horn not working (excivicboy96)
also gotta take into account the clock spring
Old Feb 25, 2007 | 03:11 PM
EJ ITO's Avatar
ok thanks guys ill try all of that and tell you the results
Old Feb 27, 2007 | 03:09 AM
EJ ITO's Avatar
alright so I pulled the bumper of, disconnected the cable from the horn, used speaker wire to see if the horn was bad but it wasn't, as soon as I touched it to the battery the horn went off, I used a test light to see if I was getting power to the horn and no power, I checked to see if I was getting power to the fuse and I was, so any suggestions?
Old Feb 27, 2007 | 03:17 AM
Ricey McRicerton's Avatar
Default Re: (EJ ITO)
Grab a Helms and start tracing back the wiring. Best of luck with it. I hate trying to track down electrical stuff.
Old Feb 27, 2007 | 08:27 AM
EJ ITO's Avatar
yeah that's what ima have to do
94accord25
Mar 17, 2010 09:37 AM
raidacaipo
Mar 11, 2009 11:40 AM
xjdmshezx
47
Jun 9, 2006 02:16 PM
2ndGenREX
Jan 24, 2006 02:34 PM
oldbeefcake
13
Feb 24, 2004 08:34 PM
